Building ring chains
/ Building ring chains #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I would like to build a set of ring chains for my tractor. I saw in a recent thread a set a guy made with 3/8" round bar. I have acess to miles of rebar drops. I wonder how some #4 (1/2") rebar would be for some rings? They would be already studded. Thinking maybe a 5" dia ring for 11.2x38 tires. I already have a lot of 1/4" welded link chain, do you think it would be heavy enough for the side chains, its for an International H.
/ Building ring chains #2
There "might" be some stretching,but I made my side chains a bit long and can adjust them by just moving a 1/4 X 20 bolt to the next link. I really don't see a problem though. Think about it....a five inch ring being pulled at four equal points around it is really gonna take a lot of power.....and TRACTION!! Plus, the treads on the tire tend to hold the chain in place. I know this every year when I try to put them on!
/ Building ring chains #3
#4 would be a lot stronger then my 3/8 round too. If in doubt....weld a bar across them...like the first cut on a pizza.
/ Building ring chains #4
Rebar might be good due to it's designed rough surface, but man it would be alot of bending and welding. Rebar is pretty hard I think, harder than avg bar stock?
Rebar? got me thinking, you could come up with all kinds of ideas, Like a solid link across the tire bent to the shape of the tread and rings on the ends for side chains to thread through.
JB.
/ Building ring chains #5
I'm not sure 1/2 inch stock would handle the strain. Most ring chains I've seen use at least 3/4 inch stock for the rings, if not heavier. I went with studded ice chains, primarily because I don't like the way ring chains grab and then slip.
They're also play **** with paved surfaces, at least the kind with teeth do.
Chilly
/ Building ring chains #6
I'd worry about rebar failing and then having a piece that may puncture the tire. A chain that fails will likely not have danger.
/ Building ring chains #7
I'm quite willing to bet the clutch would burn up before an H would spin the rebar.
I don't believe that old H could break a #4 bar, so you must be questioning my welding. LOL My father does a little recreational blacksmithing so He is going to make the rings for me in his forge. He says let them cool slow and they will work fine.
/ Building ring chains #9
In time, they do wear. :)
Not questioning anyone's welding at all. :D
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
HARDEE DITCH BANK MOWER (A64278)
HARDEE DITCH BANK...
