Building our retirement home
   / Building our retirement home
The safe/media room is approximately 16x14, with an additional attached bath. The cap for this area was 3 1/2" thick. They built a series of walls on the underside, put on decking, vapor barrier and rebar. I positioned 3 forms for the AC vents and 2 pvc inserts for electrical.
The underside photo was taken before the supports were fully in place. It would have been difficult to even slip between the studs by the time they finished.
   / Building our retirement home #152
Is the wood framing on the ceiling still there?
All the framing has been removed.
The walls were poured with a lip, so the cap sits on the surrounding lip and and is reinforced.
   / Building our retirement home #154
How's the cap attached to the walls? Or does it just sit on the lips.
   / Building our retirement home #156
It sits on the lips but, of course, the rebar goes edge to edge.
So it just sits there? That would worry me. If those wall ever shift or spring. It could be bad.
Now if the rebar came up out of the wall and was bent over to tie the two together that would be ideal. Plus the lip.
   / Building our retirement home #157
Did you allow for outside air exchange in the safe room, if so how?
OK ..... You thumped me in the head and made me take a look back. I posted a pic, I think it's post 114, that shows the wall rebar. Obviously, it was planned to provide rebar extending into the sides of the cap. So, we'll just overlook my mental impairment and assume I answered correctly in the first place :)
Yes, although it may technically degrade the term "safe room", it is vented to the house A/C. You can see the vents in post 153, although the wood forms had not yet been removed.
   / Building our retirement home #160
Now I remember looking at those pictures. But I've slept since then. :).
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
