Building our land leveler
   / Building our land leveler #1
BMan2005
Platinum Member
GA
17' New Holland Workmaster 60 & 02' Kubota L3000F
Pretty much have my plan together in my head & going to pick up supplies tomorrow. Will be using mostly metal out of a friend's recycling yard & some new things I'll be purchasing. I'm sure it won't be as nice as some you can purchase, but for the diy that wants something just serviceable I figured you would like me sharing the build. I plan to over build a little bit, and heavy.
We need it to help put a final smooth level on land we had cleared this past year & smooth our 1500' drive (soon to be double) so we kinda needed one.
Build pictures to come
   / Building our land leveler #2
Not quite sure what your design will be, but if you are going to use it for a drive, it would be nice to make it adjustable for tilt, so you can build and maintain a crown to the road.
Just straight blades. I have a Landpride 4096 to keep a crown on the road. From all the reading I've done most everyone who has them with angle says they honestly don't move much dirt to the center for a crown. Have you had a different experience?
It'll be 8' wide x 6' long btw
   / Building our land leveler #4
The only I know of to make a crown with a land plane is to adjust one lower link on the 3 point to make the crown side higher.
Maybe that's what airbuscuit meant, having some tilt adjustment in the blades. I automatically took it as angle, which still may because I haven't ever ran one either way. But I could definitely see tilt doing it.
   / Building our land leveler #6
Are you building something like this?
   / Building our land leveler #7
Or a grader/scraper
2nd video maybe I should have wrote land plane? I know it goes by a few names, kinda confusing. The Twin blade set up.
Also I was thinking to set up the blades to cut 1.5" below the skids on it, sound about right?
Material list complete. Final build will be 8' wide x 6' Long.
2- 12" I beams cut 6' long for side's
1- 6x4x 3/8 tubing for front cross member
1- 4x4x 5/16" tubing for rear cross member
6- 2x3x 1/2" pieces of angle iron for cutting edge to me mounted to and various brackets.
2- 8' double sided 1/2" cutting edges
4- packs of bolts for cutting edge.
I have some 2x2" & 2.5x2.5" square tubing laying around that will be used to build the 3pt & top link mount/brace as well.
2011 FORD F-250 FLATBED (A45046)
2011 FORD F-250...
AGT LRT 23 Stand On Mini Skid Steer (A44501)
AGT LRT 23 Stand...
More info coming soon! (A44572)
More info coming...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
CAT 420F IT BACKHOE (A45046)
CAT 420F IT...
GENIE GS1930 (A45046)
