Building Lake Corona
   / Building Lake Corona #1,261
Man that sure looks good! I hope it works! What a sweet little spot that is going to be when it fills up. 🤞
   / Building Lake Corona #1,262
Now is the time to set your posts for a dock. One of my many mistakes was not doing this myself. Once my pond filled up, we fished from the shoreline, or in a rowboat.
Over the years, the shoreline grew more and more plants in the water, and it has become more challenging to enjoy fishing from the shoreline. I have to build a dock, or two, so we can enjoy fishing the pond without constantly getting caught in all the stuff in the water.
Unfortunately time is not on my side for a dock. My slopes have a pretty steep drop so should help with how far out I get growth. If it does fill and become a problem I'll be sure to post for a big helping of "I told you so"
The big stump is moved. Last bag of bentonite going down. I used everything this machine had to move it. Not sure what it weighs but its a lot. Was able to get the 7' forks under it and lift enough to skid it.
   / Building Lake Corona #1,265
That needs to go in the bottom of the pond! So only you know where the big bass are hiding!
   / Building Lake Corona #1,266
I'm with Eddie on this - just set posts, leave the rest of the dock for later. I dug a footing and used 8" tube forms and left an anchor in the top when I last had my pond dry so it could be re-scooped - pretty minimal effort to set up the posts now, build the dock next year.
I guess the dock may be one thing I may want that I just don't realize yet. If I can get to it I may take the advise.
   / Building Lake Corona #1,268
I guess an in-between measure would be to set some footings with only a small rise like 6" of a tube form above it.. perhaps also leave some rebar sticking up a foot and toss some pipe over it so nobody gets skewered
then later if you decide you don't want a dock, or just never do decide that you do want a dock, there's nothing to see and not much in the way
and later if you do decide to build a dock after all then you stick a form down into the water over the stub that's there, and fill with concrete... though you may have to use something like PVC pipe as the form in the water (or something like 8" Ceme-Tube Standard Concrete Forming Tube which I have no experience with) ... and hope you put the dock footings in the right spot for where you now want the dock...
   / Building Lake Corona #1,269
Another mistake that I made was making the shoreline drop off too steep. I marked around the pond with red paint to show were the water would be when full, and then I graded the ground above the waterline so it would be easy to mow. Not much of an angle. Then on the water side, I wanted it to drop off as fast and as steep as I could to discourage reeds and other plants from growing there.
The thing I didn't think about was that the pond is only full for a short period of time, and as it drops, I have to deal with mowing the steep drop off. In places, this is very scary. Another thing I didn't realize was that the plants that grow in just a few inches to a foot of water will grow right up to the edge of the water and then take over the grass if not mowed constantly.
So now my challenge in life is mowing reeds at the edge of the water. Two years ago, I got a bigger tractor and a 12-foot batwing. This has made it a lot easier to get to the edge of the water and not have my tires any closer than I have to.
If I was doing it all over again, I would of made my shore line shallower, and easier to mow. The first five years was easy, but as Mother Nature takes over, she does what she wants!!!!
My terrain and surrounding hillsides kind of dictates the steepness. Not much of a choice on 3 of the sides on how steep it is. On the plus side the ctl and front brush cutter gives me about 8 ft of reach. If I end up with that problem it means it has filled up so I'll take it.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2008 KOMATSU PC138USLC-8 EXCAVATOR (A60429)
2008 KOMATSU...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
