Building Lake Corona
/ Building Lake Corona
Also, it will take many yards of dirt to change the slope of the front face. And if you change it very much you'll start to crowd your pipe inlet.
I have one coupling I didn't use and about 8ft of pipe left to extend if needed. Probably a full day of moving dirt to get the slope where I want it.
/ Building Lake Corona #722
I think if it's an issue to you, go for it. You'll regret not doing it. And you are way too deep into this project to end with regrets!!!! :thumbsup:
/ Building Lake Corona #723
Nothing a coupling and short piece of pipe with glue could correct in minutes.
/ Building Lake Corona #724
Yep. The pipe was secondary. The yardage is the big issue. He'll get it right or he'll keep working at it!!!
/ Building Lake Corona #725
What is your slope now? I think 3 to 1 is as steep as you would want at the waterline and above.
/ Building Lake Corona #727
Have you gave any thought to getting rye grass planted, while adding finishing touches, too help slow down a heavy rain if one comes along?
hugs, Brandi
/ Building Lake Corona #728
EXCELLENT ADVICE !!
You are correct. Those extra few degrees adds up to a lot of yards. I'm guessing my slope is currently about 1.5/1. Need to get it to 2/1 at a minimum. Probably puts the bottom around the end of the inlet pipe. Calling for 1/2" to 1" of rain tonight so may be a few days before I get back in to wrap things up.
hugs, Brandi
Considering I've been building this on the fly with no real plan I haven't thought about it yet. Figured as soon as I put some down I'd be digging it right back out or tracking all over it.
/ Building Lake Corona #731
Rye grass is cheap and easy to apply, just spread and water. Running over it building just covers it up. No need to worry about digging it back up. It's the point of getting roots established to stop erosion. I moved a lot of Bermuda grass in moving and enlarging my dam. It came back up, but it is not an annual. You could start on the new walk/tractor paths and the back side of the dam. Get roots growing............being a cheerleader here.
hugs, Brandi
Just enough rain last night to make things sloppy. With the ground wet you can make out the walk paths and see the pond edge much better now. It's going to take a lot of water to fill.
20201110_081203
/ Building Lake Corona #733
Great pic!!!!
It's still raining off/on here this morning. No runoff yet. Our next chance of rain is Saturday.
Great pic!!!!
No runoff here either. Just a very light spitting rain at the moment.
Here's a before/after pic from when I started to now. I've added a yellow arrow to the same tree in each pic for reference.
Pond_Before_After
/ Building Lake Corona #736
Oh Wow!!!!! That's an excellent before/after!!!! What a change for that area!!!
/ Building Lake Corona #738
Now you have me second guessing myself. Worked for a couple of hours this morning leveling out the first area of the hillside I started on. Hoping to head back out this evening and start cutting a walk path along the west side of the pond.
2020-11-07_10-35-01
Pond_Before_After
Great photos, and great progress! Maybe you could just put in pier poles for now, since lumber is high? But at all costs, keep the wifey happy.
I've told you before on your home and your venue, your team has great vision. You will enjoy this pond.
/ Building Lake Corona #739
hugs, Brandi
x2. I used to plant conservation mix with oats or annual rye on the snow on woods roads, to quickly stabilize the soil in spring. They don't have to be certified seed either, I always just used feed oats.
When seeding in spring the conservation mix would green up within days.
/ Building Lake Corona #740
This is funny, one of Muhammads own threads turning political
:laughing:
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
