Building Lake Corona
   / Building Lake Corona
Really happy with the progress the last two day. Was able to get in at least 5-6 hours each day and moved a lot of dirt. The dam is now at water height across 2/3 of it. Need to get the pipe ordered for the overflow and then will work on expanding the base of the dam, installing overflow, and building free board. Here's some pics as of this morning. Rain is on the way for the next couple of days.
2020-09-08_11-00-40
2020-09-08_11-01-17
2020-09-08_11-01-26
2020-09-08_11-01-39
2020-09-08_11-02-09
   / Building Lake Corona #582
Very good progress!!!! Crappy weather moving thru for the next few days.....
   / Building Lake Corona #583
Looking good. Have you estimated the final surface area yet?
   / Building Lake Corona #584
I do not know much (if anything) about building a pond, but I have thought about building one for over 20 years, so I have put a lot of consideration into one.
I think if I was going to build one, the first thing I would do is to put a large (8"-12") pipe in the bottom and lay it through the dam, so I could keep the pond drained through out the project. As the op has done, then build the dam and pond.
Keep the pond drained as all the grass on the dam and around the pond grows in the runoff areas, only then would I install a Keystone type butterfly valve on the end of the disharge pipe, so that I could drain any muck that would build up to the level of the inlet of that discharge pipe, and also be able to control over topping the dam if needed.
Not sure how well it would work, but I would think it could help with maintaining the muck level.
Got it. Sweet! You packing with a load of dirt in the bucket? It is looking good. Gonna be an impressive dam.
hugs, Brandi
No dirt in the bucket. At the moment the backside is too steep for me to back up with a load of dirt. Will need to expand the base to lesson the slope. I don't really have any concerns over compaction though. Lots of trips building this up seems to be doing a very good job. That showed the two times the dam was topped with little to no damage.
General Purpose Loader Bucket (A59228)
General Purpose...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
YANMAR VIO355 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO355...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
240156 (A56859)
240156 (A56859)
