Building Lake Corona
   / Building Lake Corona #761
I'm reading the same Eddie however I'm planning to go ahead and bring it closer to a 3:1 slope before wrapping this up. Not only for piece of mind on erosion but for a safety factor as well. As is if someone fell into the water or slid on this bank you could never stand back up. Just too steep.
For erosion, the most important slope is that which is at the waterline (low and high) and above. If you need to go steeper below the waterline to get a lower slope above, to avoid moving 'too much' dirt... that is what I would do.
   / Building Lake Corona #762
Good idea.
Picked up a job the last week cleaning up fence lines and clearing some overgrown land with the track loader and cutter. Finished that up yesterday. Trackloader is back home and spent a little time this morning moving some dirt to the dam. Rain this afternoon.. Fresh dirt in the pic will be the final grade. Should be about an 8 to 10 hour job to finish up. On the plus side the pond is getting slightly bigger. Maybe not by volume but by surface area.
2020-11-21_10-03-56
   / Building Lake Corona #764
The size of the dam is displayed in this pic!!!!
That's going to be tricky at the pipe. Is the puddle solid bottom so you can get in it?
We have a chance of rain for the next five days. One of them will surely get you.
   / Building Lake Corona #765
Did I miss how you built your emergency overflow? Did you cross over one of the ridges?
Puddle is actually about 6 feet deep. Will pump it out and extend the pipe
Haven't addressed it yet. Will probably cut the overflow into the hillside east side of the dam. Opposite of what's shown in the last pic. Will cut a path into and down the hillside where the dam meets untouched ground so water doesn't flow down the built dam. Will line with some rip rap rock to help control erosion in an overflow event.
   / Building Lake Corona #769
What a project!!!!
I'm very impressed with what you have accomplished with your CTL. Looks like a toy sitting in the Lake. :thumbsup:
   / Building Lake Corona #770
You mentioned riprap in your reply about the overflow. Is it expensive there? Instead of spending so much time adding dirt to the inside of the dam to make it safer for people to get out of the water if they slide in, would it be possible to add riprap to the to of the dam where the water will be? This is done on large Reservoirs to control erosion from the waves of the Reservoir, and to discourage animals from digging into the dam, but it would also make it a lot easier to get out of the water if somebody fell in. As it is, with what you are doing now, I don't see it being any easier to get out of the water with the additional soil that you are adding.
2025 GPS Trailer (A56858)
2025 GPS Trailer...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
Blue Diamond 103709 (A53317)
Blue Diamond...
2007 Ford E350 (A55973)
2007 Ford E350...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
