Building Lake Corona
/ Building Lake Corona #761
I'm reading the same Eddie however I'm planning to go ahead and bring it closer to a 3:1 slope before wrapping this up. Not only for piece of mind on erosion but for a safety factor as well. As is if someone fell into the water or slid on this bank you could never stand back up. Just too steep.
For erosion, the most important slope is that which is at the waterline (low and high) and above. If you need to go steeper below the waterline to get a lower slope above, to avoid moving 'too much' dirt... that is what I would do.
/ Building Lake Corona #762
Good idea.
Picked up a job the last week cleaning up fence lines and clearing some overgrown land with the track loader and cutter. Finished that up yesterday. Trackloader is back home and spent a little time this morning moving some dirt to the dam. Rain this afternoon.. Fresh dirt in the pic will be the final grade. Should be about an 8 to 10 hour job to finish up. On the plus side the pond is getting slightly bigger. Maybe not by volume but by surface area.
2020-11-21_10-03-56
/ Building Lake Corona #764
The size of the dam is displayed in this pic!!!!
That's going to be tricky at the pipe. Is the puddle solid bottom so you can get in it?
We have a chance of rain for the next five days. One of them will surely get you.
/ Building Lake Corona #765
Did I miss how you built your emergency overflow? Did you cross over one of the ridges?
Puddle is actually about 6 feet deep. Will pump it out and extend the pipe
Haven't addressed it yet. Will probably cut the overflow into the hillside east side of the dam. Opposite of what's shown in the last pic. Will cut a path into and down the hillside where the dam meets untouched ground so water doesn't flow down the built dam. Will line with some rip rap rock to help control erosion in an overflow event.
/ Building Lake Corona #769
What a project!!!!
I'm very impressed with what you have accomplished with your CTL. Looks like a toy sitting in the Lake. :thumbsup:
/ Building Lake Corona #770
You mentioned riprap in your reply about the overflow. Is it expensive there? Instead of spending so much time adding dirt to the inside of the dam to make it safer for people to get out of the water if they slide in, would it be possible to add riprap to the to of the dam where the water will be? This is done on large Reservoirs to control erosion from the waves of the Reservoir, and to discourage animals from digging into the dam, but it would also make it a lot easier to get out of the water if somebody fell in. As it is, with what you are doing now, I don't see it being any easier to get out of the water with the additional soil that you are adding.
Too steep at the moment to add rip rap. Would take a bunch because it would roll to the bottom at this slope so the entire slope would have to be rocked. Will bring the slope out as planned then only add rock at the waterline later if erosion becomes a problem.
/ Building Lake Corona #772
Yep. Good plan.
/ Building Lake Corona #773
Maybe cut in a little ledge just below the W/L to allow for the addition of rip rap? Would seriously help cut down on the amount needed if you added later. I would be inclined to add it now while dry though.
/ Building Lake Corona #774
Rip Rap might be a cosmetic addition if that appeals. It certainly won't be needed for erosion in this Lake. Can't imagine any sizeable waves. :)
/ Building Lake Corona #775
Jeremy, we've got an inch of snow and it's still coming down.
/ Building Lake Corona #776
I think the rip rap could definitely help especially on the softer disturbed manmade dam portion helping protect it while the vegetation takes decent hold. If you don't get much wind, maybe it's overkill but I would hate to have to try to shore it up later thus the suggestion about making a ledge.
/ Building Lake Corona #777
I'm basing my wind comment on the surrounding timber. :)
/ Building Lake Corona #779
Well... JK did just cut a large swath through his forest. Let's hope he didn't create a wind tunnel! :eek: :D
That right there would be my luck!!!!
This project has exceeded anything I envisioned in the beginning.
/ Building Lake Corona #780
he might need a "NO WAKE" zone close to the dam.
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New/Unused Pallet of Ground Protection Mats (A65583)
New/Unused Pallet...
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
King Kutter II Tiller for sale.
King Kutter II...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
1995 CATERPILLAR 140G MOTOR GRADER (A65053)
1995 CATERPILLAR...
