building barns, sheds, houses - almost free
   / building barns, sheds, houses - almost free #1
North Texas
Kubota B7800
A lot of folks don't know this stuff exists yet so I figured I'd post a little bit and see if anyone was interested.
You can make blocks from shredded paper and portland cement that are both strong and have a high insulation factor - you can build just about anything out of them and you can get the paper free, in fact your doing us all a favor by keeping the stuff out of the landfills. If anybody is interested in how to do this let me know - it's easy and cheap - look up "papercrete" on a search engine and you'll find some good links.
You can mix huge loads of the stuff several ways using your PTO and a homemade mixer built out of a truck rear end, mower blade and a metal stock tank. It's easier to lay than brick or stone and a lot lighter weight but strong enough to withstand 150 MPH wind.
   / building barns, sheds, houses - almost free #3
Thanks Doug, I'll check it out.
   / building barns, sheds, houses - almost free #4
Hello Doug, good to see you here and also welcome. Sounds interesting, I need a good shop. When I get the time I will check out the links I just wnated to welcome you on here. We are good people to chat with.......teddy
   / building barns, sheds, houses - almost free #5
Welcome to TBN Doug. Thanks for the links. This sounds interesting. /forums/images/graemlins/cool.gif
here's some photos of stuff built (or being built) out of papercrete
   / building barns, sheds, houses - almost free #7
Might try building a new pump shed out of this Thanks for the heads up.
   / building barns, sheds, houses - almost free #9
Yes how does it hold up to rain ? From the pics those constructions seemed to be in an arid climate. Is it required to stucco over it ?
You have to waterproof it - elastomeric paint works well. Many people have built these in very rainy and humid climates and as long as they are waterproofed they work fine - if they are not waterproofed they will eventually start to deteriorate. I am planning to build my main house in a fairly rainy part of North Texas - I'm going to use papercrete for the walls and put a metal roof with a wraparound porch to reduce the problem to the point of insignifigance but I will still paint the house with a good latex to seal it. Domes are possible (even easy to build with papercrete) in wet climates but you REALLY need elastomeric roof coating after they are finished - papercrete will soak up and wick water if not coated. In arid climates with only ten instances per year of rain, coating is not all that important - papercrete has to get very wet many, many times before it will begin to break down.
2023 RHINO X1406 LOT IDENTIFIER 61 (A53084)
2023 RHINO X1406...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
