building barns, sheds, houses - almost free
   / building barns, sheds, houses - almost free #1
North Texas
Kubota B7800
A lot of folks don't know this stuff exists yet so I figured I'd post a little bit and see if anyone was interested.
You can make blocks from shredded paper and portland cement that are both strong and have a high insulation factor - you can build just about anything out of them and you can get the paper free, in fact your doing us all a favor by keeping the stuff out of the landfills. If anybody is interested in how to do this let me know - it's easy and cheap - look up "papercrete" on a search engine and you'll find some good links.
You can mix huge loads of the stuff several ways using your PTO and a homemade mixer built out of a truck rear end, mower blade and a metal stock tank. It's easier to lay than brick or stone and a lot lighter weight but strong enough to withstand 150 MPH wind.
   / building barns, sheds, houses - almost free #3
Thanks Doug, I'll check it out.
   / building barns, sheds, houses - almost free #4
Hello Doug, good to see you here and also welcome. Sounds interesting, I need a good shop. When I get the time I will check out the links I just wnated to welcome you on here. We are good people to chat with.......teddy
   / building barns, sheds, houses - almost free #5
Welcome to TBN Doug. Thanks for the links. This sounds interesting. /forums/images/graemlins/cool.gif
here's some photos of stuff built (or being built) out of papercrete
   / building barns, sheds, houses - almost free #7
Might try building a new pump shed out of this Thanks for the heads up.
   / building barns, sheds, houses - almost free #9
Yes how does it hold up to rain ? From the pics those constructions seemed to be in an arid climate. Is it required to stucco over it ?
You have to waterproof it - elastomeric paint works well. Many people have built these in very rainy and humid climates and as long as they are waterproofed they work fine - if they are not waterproofed they will eventually start to deteriorate. I am planning to build my main house in a fairly rainy part of North Texas - I'm going to use papercrete for the walls and put a metal roof with a wraparound porch to reduce the problem to the point of insignifigance but I will still paint the house with a good latex to seal it. Domes are possible (even easy to build with papercrete) in wet climates but you REALLY need elastomeric roof coating after they are finished - papercrete will soak up and wick water if not coated. In arid climates with only ten instances per year of rain, coating is not all that important - papercrete has to get very wet many, many times before it will begin to break down.
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A53426)
2023 EAST TEXAS...
2024 JOHN DEERE 3039R LOT IDENTIFIER 152 (A53084)
2024 JOHN DEERE...
2018 COLOMBO TM LOT IDENTIFIER 171 (A53084)
2018 COLOMBO TM...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
