Building Advice
   / Building Advice #31
Even if local designs are weak, it is better to figure out ways to strengthen them than to adopt a completely different building strategy. In poor countries people build structures that are often not expected to last very long. The cost of building a strong structure is usually more than building a cheap one so the cheap one gets built. For example, in many or most poor countries, when bricks are used they are set in a single course without any reinforcement except at the corners. Simply using dual interlocked courses of brick and making sure that the corners are appropriately reinforced with adequate rebar can substantially improve matters. Adding a little rebar in the middle of the wall wouldn't hurt either. I'm sure there are masons or web sites on building that would explain some of the things necessary to strengthen walls. Any structural engineer could help and I know there are organizations like Architects without Borders that would be happy to share experience with adapting local building techniques. Check out some of the innovative construction proposed as replacements after the Haiti earthquake that destroyed hundreds of thousands of these poorly engineered local homes.
Regarding the use of corrugated steel roof material in a sideways orientation: That would be fine if you just want to keep out the sun but it will leak like a sieve. You have to overlap the material so rain cannot get in and using the panels turned 90 degrees will not work.
Well said. You can use nearly any material if you put enough brain power and engineering behind it. I would ask the locals how they would build such a structure. I'm sure there's some talented folks around there that can provide you with some ideas of how to use their building materials. Combining that with some western methods and you should have a good structure! :thumbsup:
   / Building Advice
Yes, CEB is one area that we (I and our local church leaders) are very interested in. Unfortunately we don't have a place where we can work to experiment with such technologies. That is the reason for this shop.
As i have been reading back through these posts, i have seen that most people were leaning towards using locally available metal to make some sort of pole barn. Which style do you think would be the best, considering that i am looking to us this shop as a general work shop, as well as a secure place to do mechanical work and eventually to house a tractor with some small implements like disks, rakes, ect.? I am not concerned about huge, clear spans. I was thinking about doing one similar to this... http://www.tractorbynet.com/forums/projects/110718-want-see-yet-another-pole.html without the loft. Im thinking that this could help to cope with the heat.
thank you
Blake
   / Building Advice
Riversedge, my initial idea was to do some sort of Quonset building. If you look back in this posting, you will see that this idea did not receive much attention. Also, after talking to a man who builds hoop houses for use as green houses he said that there is allot of flex in the 20' wide hoops. He said that it was too much flex to try to turn into a rigid structure.
For that reason i have decided to look into building some sort of pole barn out of locally available metal.
2014 Grove TMS700E 60 Ton 4 Section Quad Axle Crane Truck (A60460)
2014 Grove TMS700E...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
1998 Ravens 39' Dump Trailer (A59814)
1998 Ravens 39'...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2003 Freightliner FLD 120 Columbia (A56436)
2003 Freightliner...
2020 Utility Trailer (A60460)
2020 Utility...
