Building a stick frame house in the woods in 90 days
   / Building a stick frame house in the woods in 90 days #2,061
Much Mo' Betta!!! Wow, that's some heavy duty washer/dryer! I can't believe how much better almost everything looks. I'm not crazy about the black can lights outside...could they be painted to match the house? I really like the lighting inside, everywhere. The fireplace room turned out beautiful. Peter, are they going to have the upper cabinets installed before final inspection or is that not necessary? How's the punch list coming? Mom is going to be happy!
mkane09
   / Building a stick frame house in the woods in 90 days #2,062
Going to be awful tight doing laundry in that room
Here's my understanding of requirements for final inspection that have to be met in order for the county to issue an occupancy permit:
  1. One cleaned up fully functional bathroom (meaning hot and cold water, working septic, etc)
  2. Ability to make food (ovens are working now, the cook top still needs duct work completed)
  3. All electrical fixtures installed and working or cover plates over all non-mandatory uncompleted work (like exterior outlets, additional ceiling lights per room, etc)
  4. All breakers clearly labeled
So upper kitchen cabinets do not have to be in, nor does the fridge.
My punch list still includes:
  1. Master bathroom vent ducted to outside
  2. Move phone and power to wall desk in kitchen
  3. About 10 trim corners need additional sanding/painting
  4. About 3 areas on the walls that need additional sanding/painting
  5. Add trim to both sides of dishwasher
  6. Make end panels math at end of bookshelf wall in kitchen
  7. Secure window well to basement wall
  8. Rake fascias
  9. Install 3x4x4 down spout adapters in 4 locations and paint exposed parts to match house trim color
  10. Missing shoe molding in a few places
  11. Power wash stamped concrete and seal
  12. Paint exterior electrical trim plates to match siding
  13. Strip and paint main and garage secondary door
  14. Replace seals around garage door
  15. Replace lag bolts for carriage bolts on railing
  16. Replace bar sink with utility sink
  17. Add 2 or 3 loads of #57 gravel to driveway, then a load or two of #10 dust, water and pack down, then spread 2" of the brown stone on top
Agreed. Which is why I want to see about getting those appliances closer to the wall. We need all the space we can get in there.
   / Building a stick frame house in the woods in 90 days #2,065
What about final inspections for all trades? Usually at this stage they have not received final on anything. Issues like those lag bolts on the deck should be caught in a deck final (I assume that is a separate permit, it is up my way). More often than not, they point out something that catches them off guard on one or more of the finals. Unless, of course, they have some sort of deal going with the inspector. Also, in my county, you can't call all of the finals and U&O on the same day. It is assumed to be a given that some of the finals will need follow-up.
I know we have all said this before, you are not getting paid (or a discount) to be the GC here. But since it seems you have to be, it may be worth checking the status on all of these inspections. Do you have online access to the permit site for your county? I can check all of that info directly rather than rely on the GC to keep me informed.
Are you hoping for U&O today?
Lee
   / Building a stick frame house in the woods in 90 days #2,066
Peter,
Looking a lot better.
After everything calms down you might want to review your pics and look and/or take new pics of the troubled spots.
Whether it passes or not, a couple items that I would want:
A railing from the deck corner out to the flower box so no falls off the edge into the box lower down on the hill occur.
Cut out that foundation corner that sticks up on the right side of the basement stairs, or at least paint it red.
The sharp corners at waist level should be rounded wherever possible. We old folks have a tendency to run into sharp corners.
Ron
   / Building a stick frame house in the woods in 90 days #2,067
Peter:
I agree with everyone else. It is starting to look really nice. Two things come to my mind: 1) Make sure the gas company converts the stovetop to LP from NG - most everyone I've seen ships setup for NG. 2) I cringed when I saw that aluminum flex pipe sitting in the window. If they use regular sectional vent pipe with an elbow in the wall, you can get the dryer much closer to wall. However, I see you went with the super tall washer and dryer. If you move the washer back as well, it could be that you would not be able to get to the water shutoffs in the event that a hose bursts.
-Stu
   / Building a stick frame house in the woods in 90 days #2,068
The washer dryer stuff are on stands. The water valves should have burst protection but open those doors and no room to move clothes.
   / Building a stick frame house in the woods in 90 days #2,069
Is the step outside the sliding glass door, near the deck, code? I thought it had to be the same height as the threshold? The way it is done in your picture, it looks like a tripping hazard.
Eddie
   / Building a stick frame house in the woods in 90 days #2,070
vent.jpg Example of dryer vents that alleviate that bumped out look. My wife religiously shuts off the water after each washload, which would be impossible with their hose setup.
These builds are always fun to watch and there are always ups and downs. Fortunately for your mom, you've been there to bring the quality up to where it should have started, not ended. I personally would not let this builder use the house as an example of their work, because clearly it is better than they would have delivered.
Great job Peter, I look forward to a smooth move-in.
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2014 International Maxxforce DT (A53317)
2014 International...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
cummins generator (A56857)
cummins generator...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
