Building a ripper claw for KX41 mini-excavator.
   / Building a ripper claw for KX41 mini-excavator.
Painted the claw "Lobster Red"
486828d1478236795-building-ripper-claw-kx41-mini-img_7058_12-jpg
I need to make an "insert" for the thumb that allows "clamping" so I can grab a bundle of bushes/sticks and pull them out of the ground.
486829d1478236795-building-ripper-claw-kx41-mini-img_7063_12-jpg
486830d1478236795-building-ripper-claw-kx41-mini-img_7066_12-jpg
No reason to just LOOK at the dang thang!
   / Building a ripper claw for KX41 mini-excavator. #42
Looks good Sodo! :thumbsup:
   / Building a ripper claw for KX41 mini-excavator. #43
Turned out fine!
Now that thumb install stands out like a ... sore thumb.
Good thing you have 5 1/2 cans of lobster red paint available.
HA !!! That's too funny. ....and an opportunity for a pun too.
I was trying to list all the Kubota touchup I "ought to do." (now that I have too much orange paint).
The tractor FEL cylinders are faded pink. Thee welded-on bucket hooks, etc were never painted. But keeping with tradition I wanna cut them all off and re-weld anyway (keeping up with the Jameses :D ) Anyway everything I could think of,,,, nothing came even close to 5 1/2 cans of painting. But "by the case" was like 2 cans free, right? At least I got a deal.
That homebrew thumb on the mini-ex never even crossed my mind, I just don't "see it" anymore. But anyway this "paint" thing is kinda new to me, I can never paint anything I build because it's never finished welding, except the ripper claw is done. And things are different now I'm sitting on 5 1/2 cans of paint. In any case the thumb has to wait until the weather warms up, like May 2017. Pat you may have to remind me.:thumbsup:
   / Building a ripper claw for KX41 mini-excavator. #45
Great work!
   / Building a ripper claw for KX41 mini-excavator. #46
Awesome work, I wish I had seen this before I started mine. I will have to add the angled gussets, and the spine T.ripper2.jpg
My mini-ex is pretty weak (3900lbs). I doubt its capable of bending the claw. But my claw steel is only 3/8 thick. I can imagine a situation jammed in a tangle of big roots where it could be bent left or right if not for the gusset.
One benefit I see from the spine is that you can roll it back on the flat spine giving more leverage to bust roots or lift on a stump on the near side.
The other benefit is in trenching, the spine opens a wider swath through the dirt, rocks, roots. I would reduce the width about 1/3, angling the gusset a little sharper so it pulls thru dirt easier.
This has been a great tool to have, digging out stumps much quicker. You go around and bust all the roots. Where with a (wider) bucket you cant even get a tooth under the root to bust it. In hard ground I can quickly loosen it and then a bigger bucket goes in and scoops faster. It makes a small machine bigger!
   / Building a ripper claw for KX41 mini-excavator. #48
My mini is supposedly 3693lbs, so close in size. I got a used cutting edge from the town garage 5/8" thick and I had a messed up shank from a tooth bar. Your claw thickness is probably sized closer to what the machine can use than what I started with. I still have a couple of bushing to replace, though I need a couple of warmer days for that.
605941d1558644935-building-ripper-claw-kx41-mini-img_5125-jpg
Planned to dig in lots of roots, so I cut in some teeth to help chew thru roots.
I used an 18v Makita saw to cut the teeth.
The material is 3/8" thick.
It was easy cutting, took just a few minutes.
605942d1558644935-building-ripper-claw-kx41-mini-img_5126-jpg
But the digging turned out easy and I didn't need the claw so I don't know if the teeth are effective.
   / Building a ripper claw for KX41 mini-excavator. #50
That looks great. I saw a ripper on ebay with teeth on the backside from manca thumbs. manca ripper.PNG
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
2018 Honda TRX250TM ATV (A56859)
2018 Honda...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Enmark Z Spray (A53316)
Enmark Z Spray...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
Mini John Deere Truck (A55853)
Mini John Deere...
