Tractors4u
Elite Member
- Joined
- Mar 10, 2002
- Messages
- 2,542
- Location
- Athens Alabama
- Tractor
- Deere 4310, Kubota L355, John Deere SST18 Spin Steer, 2006 Polaris Ranger
I started this project about 3 years ago and it got sidelined until a couple of weeks ago. It is a pulverizer like many landscapers use. I priced one once and they were going for around $1000. My goal has been to spend the least amount of money possible building this one. I managed to lay my hands on a couple of I beams for the frame. A Yanmar tiller bracket is now the toplink bracket. The roller is made from a piece of 4.5 inch diameter, about 3/8th inch thick pipe. The end caps of the pipe with the bearings are from the gauge wheels of a Hinomoto tiller. The spikes on the roller are scrap pieces of re-bar. So far I have bought 2 springs and some paint to paint it with. I have enough 1/2" bolts for all of the scarifers but I will have to buy some lock washers. I may end up buying all new fasteners before it is done. The weakest link I think is the spindles on the end of the pipe. If they fail I will go with plan B and buy some bearing blocks and redo the roller. The spikes on the roller are longer than the spikes on a store bought and with 2 I beams it is much heavier. I should have the rest of the spikes welded on and the whole rig painted by this weekend. I can now understand why they cost so much. Mine has 25 scarifers, which means 25 pieces cut and 25 holes drilled. It takes 2 pieces of angle iron to hold the scarifers. 50 pieces cut and drilled and then welded on. 6 rows of spikes on the roller. 17 spikes per row. 17 X 6 cut and welded.
