Building a log splitter, need hydraulic help!!
   / Building a log splitter, need hydraulic help!! #11
</font><font color="blue" class="small">( no thats not it, the cylinder isn't even connected to the slide right now )</font>
dont be so sure, cylinders themselves can bind, things like bent rods, dented tubes will do that. we have a garbage truck at work that had a cylinder that right from the day we got it appeared to stick at one point, the factory rep came out and they are pretty sure its got a dented tube, maybe dropped durring manufacturing etc, tommorow they are installing a new one
   / Building a log splitter, need hydraulic help!! #12
Jimmysisson
I wouldn't put a "T" anywhere in a splitter system, there is no need.
Oil should flow from Tank through strainer, pump, spoolvalve, filter and back into tank for a complete circuit.
For slow/erratic operation I would check the following first. Strainer clean.
Suction side fittings tight so you are not sucking air.
Using the correct hydraulic fluid for your ambient temperature.
If this is a homemade system, and the above items are OK, have you calculated cylinder cycle times based on pump outputs(IE: are you expecting more than your pump can possibly give)? If this is a new problem for a formerly good working system, you might have a pump or cylinder issue.
11' CONTAINER (A52706)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Westerndorf 10' Box Blade (A59814)
Westerndorf 10'...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
