Building a footbridge
/ Building a footbridge #21
Great project and nicely documented for us Rob, thanks! Very clever how you used the VW wheels and towed the bridge as a trailer. Also very well thought out on getting the new one in place, removing the old etc. Did one of you have experience with this sort of thing?
Thanks for sharing your work /forums/images/graemlins/smile.gif
/ Building a footbridge #22
thats pretty cool. I have a bridge about that size that i made with telephone poles. Now I know how to replace it.
Hey can you tell me and made maybe show a pic of what you have in the middle of your bucket on the bx. Is that something you made and added?
/ Building a footbridge #23
Very Nice!! Could you give an idea of the cost break down for this project? /forums/images/graemlins/cool.gif
/ Building a footbridge #24
Micheal looks incredibly like a fellow I know who lives in RI. His last name wouldn't be Marchetti would it?
Thanks guys!
RobS - I'm a structural engineer and dabble with bridges occasionally. We've built a few others in the past. Michael is a carpenter, so we brainstorm about how to execute these projects.
TomPenny - My dealer welded a hook on the bucket prior to delivery - pic attached.
Nasty - I got a grant for $3200 for the project. It came in well under $3k. I had the bar joists donated, but gave the woman (a single mom) $300 for them. She was thrilled.
Arbo - nope different guy!
</font><font color="blue" class="small">( How much weight is it rated for? )</font>
More than it will ever see!
Standard pedestrian live loads are 85 psf, this one is good for over 150 psf. I didn't need the middle stringer, but wanted to use 2x decking, so there it is. It's really stiff - a friend of mine weighs about 280 and I told him to jump up and down in the middle. It barely vibrated.
/ Building a footbridge #29
Hey, that is a great looking bridge. I know it was a hard job but I bet you get a lot of satisfaction looking at it.
Great Job!!!
/ Building a footbridge #30
Very Nice, Thanks for the pics.
/ Building a footbridge #31
Excellent job and extremely well documented!
/ Building a footbridge #32
I'm needing to build a bridge across a creek on my place, however it will need to be strong enough to drive a 6000 lb. tractor across. Will bar joists like you used be heavy enough or will I need to use I-beams? I will be spanning approximately 24'. I am not an expert at this type thing, but I do enjoy a challenge and the idea of doing it myself. I recently built a 27 X 24 pole barn and prior to that a 28 X36 log cabin, all without any previous experience. Both turned out very well in spite of my lack of formal training. How about the bridge? Would you suggest leaving that to an expert?
I don't think you'd have any insurmountable problems building your bridge, but I'd recommend getting a structural engineer to size your stringers. Bar joists come in many sizes, and there are a few factors involved, such as bridge width, number of stringers, and spacing of lateral bracing.
Many steel yards will spec beam & joist sizes at little or no charge. Even if you have to hire an engineer to check sizing, it's an easy calculation and should not be costly.
/ Building a footbridge #34
Radair,
Excellent job on the bridge! Like TNhobbyfarmer, i also need a bridge but not for the tractor...just horses and 4wheelers. My problem is that in E. TN, the ridges are so close together that my creek goes to flood once or twice a year. And let me tell you, it pushes some serious debris downstream. My banks are 6' tall and the bank to bank is over 35'. I have been scratching my head for 3 years now over a way to get the thing high enough too not get caught by the debris, AND not cost a fortune. I am leaning towards pouring two abutments that terminate 4' above flood stage. Then span it with I-beams..that way nothing will be "hanging down". Anyway, it's one of the first things on the "retirement list" which keeps growing every day! /forums/images/graemlins/smirk.gif
RD
/ Building a footbridge #35
I have a program called PC frame, which is rather old but it works.. It is used to do structural calculations including the bend through of the beams at a given load.
I could send it to you but it is in Dutch so i dont know if you will be able to work with it... /forums/images/graemlins/crazy.gif
Yes, maintaining adequate freeboard is critical, as fast-moving debris can do major damage. We were fortunate that this project site has a big flat basin, so the water level fluctuates very little. Another bridge we did is a backwater area for a significant river, so although the water can come right over the bridge it doesn't move at all.
Here's a pic of that one (50' span) before the wood was put down:
And a photo of the same under flood waters:
/ Building a footbridge #38
This bridge is very similar to what i will be building. My creek is so pwerfull, that it has washed out the county bridge. I kicked around a suspension, but that gets really involved....looks cool though! Thanks for the pic's! BTW, is there an easy formula for weight-span for using I-beams? Such as a 40' x 6'(finished width)that needs to carry a ton to a ton & a half ? I am curious as to the minimum size of the I-beams.
I have access to a couple of old county bridge beams, but the darn things are 45' and about 3' tall. I even went and looked at them, but geeze, moving them would involve alot of resorces. My neighbor wanted to winch them up ontop of his wrecker a frame and try and "drive them", but i think it would crush his wrecker like a Tonka toy. I guess it could be done with an set of axles and make a long trailer out of each one, but then swinging them into place is a 'nuther can of worms. /forums/images/graemlins/crazy.gif
Anyway, i think i would rather go your route, and be able to manage the smaller beams with a minimum of equipment, as i know that i will end up doing 90% of the work myself!
RD
/ Building a footbridge #39
Just out of curiosity, why did you pre-cast the abutments in your garage?
Whenever I had had a similar job to do I poured them in place using a form, which I always thought set them perfectly in the ground.
Maybe I can learn something here.
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
More Info coming soon (A66738)
More Info coming...
PORTA POTTY (A68842)
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
