building a firewood processer
/ building a firewood processer #41
bear. you will be ok with one tank. I'm running 3 pumps (25gpm) with a 25 gallon tank that has 4 pails of iso 32 oil and when we are running it hard the oil only goes to 120 degrees
i was hoping you would say that.running two tanks would've cost me a bundle to fill up:thumbsup::thumbsup:
just a few pics,Almost complete
/ building a firewood processer #44
looks good. Too bad the pics wernt a bit bigger:thumbsup:
ya I know,I took them with my Black berry.I'll try to get better ones .I had if fired up last night.Goes though wood pretty fast.Still need to fine tune the saw cylinder for the down stroke.The pressure reducing valve is very fussy.Either to much down force or not enough.More tinkering today:thumbsup:
/ building a firewood processer #46
Would someone be able to let me know what kind of white valve is on Glastrons processor? i am looking at the white valve that sort of looks like a shutoff valve, i may be completely wrong but any help would be definately appreciated.
I am in the planning stages of a processor. Plans are as follows
Perkins 80HP diesel
Double pump. 15Gpm for Ram and 30GPM for saw,
Used Parker F11-019 motor for saw
5"Bore ram cylinder
Just not aware of the white valve on glastrons processor, any help is appreciated.
Thank you!
/ building a firewood processer #47
Chulzebosch.. the white valve is used to shut the saw motor off when it is stowed. we just dump the oil to tank when stowed and when we start to lower the saw the valve start the saw . It came from a telephone pole digger truck, it is used to stop the auger when it is placed in the stowed position. It is a Cross hydraulics VS2 unit which has been modified with a spring and adjustable bolt added on the end. Jim http://www.crosshydraulics.com.au/files/products/mobileDirectionalControlValves/VSSeries.pdf
/ building a firewood processer #49
need some info from you hydraulic experts.I'm building a firewood processer.It has three hydraulic motors to run the conveyers,one cylinder to clamp the log,one cylinder to lower the saw,and one motor to turn the saw.My delema is how do i plumb this thing? And what valves do I need ? I know how to plumb for the conveyers but I don't under stand how to get the saw motor turning then lower the saw.It is based off the DYNA wood processer that runs off a PTO pump.If you say call them,I already did and won't give any info Dyna Firewood Processor Video
I have a 21 gpm PTO pump,2 cylinders,one high speed saw motor running 3000 rpm 19 gpm , three low speed motors and a pressure relief valve.What else do i need ?A drawing would be nice:confused::confused:
You want an open center three way manual spool valve with a sequence valve. Sequence valves allow a function to happen, then allow flow to another function. In other words, you move the spool valve to clamp. The ram than runs the clamp runs down, the sequence valve then allows flow to a pressure switch, turning on the motor. Then you move tyne lever the opposite way, and the process reverses.
You should draw out your components as a schematic so you can begin puzzling out the fittings you'll need.
http://www.northmanfp.com/pdf/ManualDCV.pdf
Edit: looks like I'm way late to the party. Smile.
SAND BLASTER AND GEAR (A60736)
SAND BLASTER AND...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2002 International 9200i Truck (A61307)
2002 International...
2014 CATERPILLAR 140M2 AWD MOTORGRADER (A62129)
2014 CATERPILLAR...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
