Building a boom for your tractor bucket
   / Building a boom for your tractor bucket #11
Groo the Square tube is double wall or 1/4" and at 3 to 4 ft it should work. I'm a bit confused at the 5000 ft pound comment. (is that what a 1000 pounds piece of equip would equates to?) I get the lifting capacity but by half that seems like a lot.
I'm definitely not a mathematician so you could well be right. If that was the case it seems I might be wasting my time.
what is the horizontal distance from the bucket to the pivot point were the FEL is mounted on the frame?
new lifting strength = old strengthxFEL length/(FEL+boom length)
so if you could lift 1500lbs and the FEL length is 6' and the boom is 4' more, your lifting strength at the boom tip would be 60% of the bucket lift, or 1500x6'/(6'+4') or 900lbs, and don't forget to subtract the boom weight from that number too.
1000lbs with a 5' lever = 5000 ft-lbs
I haven't run the numbers , but my gut reaction is it would take a very high strength steel to take that bending force in a 2" square tube, and the mild steel you'd probably end up with wouldn't stand a ghost of a chance. Putting the tube at the bottom of the bucket an supporting the ends with chain from the top of the bucket could handle it no problem.
10222 (A56858)
10222 (A56858)
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
15200 (A56857)
15200 (A56857)
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
