Backhoe BUILDING 2015 BACKHOE SUBFRAME
/ BUILDING 2015 BACKHOE SUBFRAME #1
cheneyejc
Mahindra 2638
Has anyone built a backhoe subframe for a 2015. Looking for some info and possible pictures. Any help would be great. Thanks
/ BUILDING 2015 BACKHOE SUBFRAME #2
Cheneyejc,
Welcome to TBN.:thumbsup: I bought my subframe and hoe from Mahindra/Bradco, so I won't help of much help. What backhoe are you going to hang on your subframe?:confused:
hugs, Brandi
I have an older Kubota 650 that was given to me. Runs Great just need to build a subframe for it.
/ BUILDING 2015 BACKHOE SUBFRAME #4
You will need to find a local welder that does custom work.
hugs, Brandi
/ BUILDING 2015 BACKHOE SUBFRAME #5
I'd get a mahindra backhoe manual and modify the kubota to closely match the mahindra mounting points. My 1710a for 1815 mounts into loader lower mount and uses a hook/pin mount at rear of tractor not on 3 point attachment. Also hydraulics come from loader power beyond kit with 3 hoses with quick connects.
/ BUILDING 2015 BACKHOE SUBFRAME #6
Or he could order the subframe half that fits his tractor and then have a local welder mate it to his BH.
hugs, Brandi
/ BUILDING 2015 BACKHOE SUBFRAME #7
hugs, Brandi
If the OP doesn't welding or have fabrication knowledge that would be the best way to go. If I had a BH I'd make my own sub frame that would be stronger than factory.
/ BUILDING 2015 BACKHOE SUBFRAME #8
I have a factory backhoe setup for my 2615. I could take pics if you like. It is a pretty good system. Takes me about 10 minutes to hook it up and I'm never in practice.
I have Knowledge in welding, I was just looking to see if anyone has built a subframe for this tractor. Just trying to see what ideas are out there. I have studied the subframe mahindra makes, just looking for other ideas.
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
