Backhoe BUILDING 2015 BACKHOE SUBFRAME
/ BUILDING 2015 BACKHOE SUBFRAME #1
cheneyejc
Mahindra 2638
Has anyone built a backhoe subframe for a 2015. Looking for some info and possible pictures. Any help would be great. Thanks
/ BUILDING 2015 BACKHOE SUBFRAME #2
Cheneyejc,
Welcome to TBN.:thumbsup: I bought my subframe and hoe from Mahindra/Bradco, so I won't help of much help. What backhoe are you going to hang on your subframe?:confused:
hugs, Brandi
I have an older Kubota 650 that was given to me. Runs Great just need to build a subframe for it.
/ BUILDING 2015 BACKHOE SUBFRAME #4
You will need to find a local welder that does custom work.
hugs, Brandi
/ BUILDING 2015 BACKHOE SUBFRAME #5
I'd get a mahindra backhoe manual and modify the kubota to closely match the mahindra mounting points. My 1710a for 1815 mounts into loader lower mount and uses a hook/pin mount at rear of tractor not on 3 point attachment. Also hydraulics come from loader power beyond kit with 3 hoses with quick connects.
/ BUILDING 2015 BACKHOE SUBFRAME #6
Or he could order the subframe half that fits his tractor and then have a local welder mate it to his BH.
hugs, Brandi
/ BUILDING 2015 BACKHOE SUBFRAME #7
hugs, Brandi
If the OP doesn't welding or have fabrication knowledge that would be the best way to go. If I had a BH I'd make my own sub frame that would be stronger than factory.
/ BUILDING 2015 BACKHOE SUBFRAME #8
I have a factory backhoe setup for my 2615. I could take pics if you like. It is a pretty good system. Takes me about 10 minutes to hook it up and I'm never in practice.
I have Knowledge in welding, I was just looking to see if anyone has built a subframe for this tractor. Just trying to see what ideas are out there. I have studied the subframe mahindra makes, just looking for other ideas.
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2008 JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
2008 JOHN DEERE...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A64553)
2014 Tennant ATLV...
