Build bridge over creek
   / Build bridge over creek #1
katyhorn
Smithville, Texas
BX 2680
Ive been reading posts about this in this forum about this. one mentions splicing two 2x12s 16 ft long together but does not go into the details of how the spkicing is done. can anyone help here? thanks!
   / Build bridge over creek #2
Give us a pic of what you’ve got to cross and what the distance is. Someone can surely help with the right info.
   / Build bridge over creek #3
How long of a span do you need? We built ours years ago with old train trestle timbers and I think our span was about 40 to 50 feet.
   / Build bridge over creek #4
Wow... that was a project! Following along here. I love bridge building stuff and have a structural engineering degree... just no practical experience.
The creek in our property has about a 24 foot span to cross. Initially it will be used for foot traffic, a riding lawnmover, and ATVs, but next year, I intend to buy a small tractor. The attached link is to a post that details what I need exactly. There are two posts on this page by Wayne who talks about splicing two 2X12 16-ft long boards, but does not provide the details and I want to make sure I do it right so as to not loose the integrity of the splice.
https://www.tractorbynet.com/forums/build-yourself/112243-wooden-bridge-span-question-3.html
   / Build bridge over creek #7
Check post 27 in that thread. He used 16 footers offset, meaning 8 foot of overlap in the middle of the 2 boards. He bolted every foot and glued it together also.
   / Build bridge over creek #8
Before you get out your sliderule :laughing: we had some big arse timbers that were able to span the creek with nothing other than the two timbers and decking (also trestle timber). We run 15,000 lbs over it, no issues. The cattle usually just cross the creek direct since it is hard to calculate the weight at any one time. The bridge is only about 5 feet above the water.
   / Build bridge over creek #9
katyhorn - good evening and welcome to TBN. Be very careful with your design. Notice the pics you posted show NO TRACTOR on that bridge. Also this is a clear span bridge - meaning, no center pier to carry the load. I would strongly suggest a review of your design by a knowledgable civil engineer acquainted with bridge design.
   / Build bridge over creek #10
Amen, your requirement is far more complex than the 12-16' spans discussed here a lot. Always build more than you plan now; as time goes on it will suddenly not hold up when you decide it would be nice to take a load of gravel across with a 1 ton truck and trailer. Many have done your type using flat bed trailer decks. A 30'er can be had pretty cheap. I knew a guy who spanned a 30' cut with a RR flat car bed. The salvage value of the waste steel from wheels,trucks, and etc paid the haul cost and renting a trackhoe to move it. You can make beams from laminated 2Xs or plywood but a little engineering will probably pay off. You can take all the risj you want but others may not see it your way. Around here fire depts are refusing to cross bridges not certified by an engineer.
Ron
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2020 Caterpillar 308 Midi Excavator (A55973)
2020 Caterpillar...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2016 Troy-Bilt 21in Push Mower (A55973)
2016 Troy-Bilt...
2014 Aerway Aerator (A55973)
2014 Aerway...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
