Build A Tractor Experts
/ Build A Tractor Experts #1
davey4000
Roxboro, NC
JD 4320, NH TC29D
I'm attempting to get a price quote for a 4320 tractor with all the possible hydraulic combinations. The problem is that the salesman at the dealership working with me either knows less than me or is determined to sell me a tractor on the lot. I'm not in a hurry at all and would prefer to order one exactly as I want. The quote they provided has much less detail, with no part numbers, than I can get myself from the JD website.
Can someone who's familiar with the configurator please tell me if these options will give me everything I'm looking for? I want to be able to use an FEL, grapple, TNT and hydraulic wood splitter. Here's the part numbers I've come up with. Am I missing or duplicating anything?
7020 - Dual Mid & Single Rear SCV
VB25511 - Electric Diverter Kit (includes two additional SCV's)
VB25512 - Power Beyond Kit
VB25513 - Third Selective Control Valve Kit
VB25312 - Top and Tilt Field Kit
Any help is appreciated.
/ Build A Tractor Experts #2
Deere doesn't offer a mid 3rd function valve from the factory (for the grapple), you will need to get this from W.R. Long...be sure to get the EH valve (nice instillation package, looks factory)
You will need 7020, VB2551, & VB2553. The power beyond kit is not necessary for your needs and the third SCV kit is redundant because of order code 7020.
Hope this all makes sense...if I can help any more let me know!
/ Build A Tractor Experts #3
I'm going to offer a different solution,
If you want top and tilt, yes, you need the
JD electric diverter kit. This swaps hydraulic flow
from your joystick for your loader to the rear
top and tilt functions.
yes, the 3rd SCV can be used to supply oil to the
grapple, using the 3rd function oil tubes, that
are part of the loader configuration. that kit is
either option code 9049, or bundle BW15260.
I would recommend keeping the power beyond kit
in place, for use with the wood splitter. this will
give you a steady flow of oil, without using a valve
at the tractor. you will then have a valve on your
splitter like you would have with a backhoe.
if you need to keep 3ph functioning, that can
be accomplished also, by connecting the return line
of the power beyond back into the rockshaft circuit instead
of returning directly to sump. from JD:
Power Beyond Kit
The power beyond kit contains rear-mounted couplers and hoses to access pressurized oil at the rear of the tractor; the kit will be used for equipment such as a backhoe or log splitter
Couplers are 1/2-in. diameter for maximum oil flow to implements
here are the codes for the tractor:
7020 Dual Mid & Single Rear SCV 1 $329.00
Optional Items:
LVB25511 Electric Diverter Kit (Open Station Only)
Includes Two Additional SCV's (Either Third and Fourth or Fourth and Fifth) 1 $1,191.00
LVB25512 Power Beyond Kit (Open Station Only)
Includes Rear Mounted Hydraulic Couplers and Hose for Use
with Backhoe on 4510-4710 and 4120-4720 Tractors. 1 $241.00
LVB25312 Top and Tilt Field Kit
Requires LVB25511 Electric Diverter Kit. 1 $883.00
/ Build A Tractor Experts #4
I have a 3320. I got the dual mid, single rear scv's. I also have the diverter to opertate top and tilt. I got the kit that runs hoses from rear 3rd scv to a mid mount, then has hard lines for the loader. Same kit fits 300 and 400 loaders. I did not get the power beyond. Everything you have listed is all that was available for a 3000 series tractor and probably the 4000 also. I ordered my tractor, but all of these options were put on by the dealer. JC
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
Frontier Root Grapple (A64126)
Frontier Root...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
