Buiding Question
/ Buiding Question #1
Believer
I want to add a shed or lean-to (enclosed) to the gable end of my barn. I have steel ribbed panels on the barn. My question is regarding how to add the header for the shed. Do cut the panels out or do I install the header over the panels filling in between the ribs? The shed will be ~40 along the end of the barn (barn is 55').
/ Buiding Question #2
Apron Flashing
A folded piece of steel used to prevent water from penetrating the space where a vertical surface intersects a roof. Where used with steel sheet roofing it should lap at least one rib and a recommended two ribs for maximum water proofing. Wider apron flashings are advised when the base of the flashing faces into the prevailing wind.
That's the condition you're going to want. So cut the sheets just below an existing wall girt/purlin, and then calculate how much further down your header needs to be to account for your new roof joists, girts/purlins and sheet thickness sitting on top of it.
/ Buiding Question #3
Your best long term bet is to cut the panel and slip a skirt flashing under the existing panel, so that it comes out over your new roof. You will need foam closures at all of the ribs to keep the wasp'ers and other critters out. Screw the panel back down with screws that have neoprene washers. Keep in mind that metal moves a lot when it heats up and cools down, caulking is short term at best.
I am a roofer by trade......but I tinker with my tractor and lurk out here hoping to learn something. ;-)
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2015 INTERNATIONAL LONESTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 INTERNATIONAL...
