Bugs killing my trees?
/ Bugs killing my trees? #1
TNTractor1
Jackson, TN
2011 JD2520
since we moved out to our 12 wooded acres, I have noticed a few trees dying for no apparent reason. Recently we had a large oak cut down because it was dead. In the stump was a irregular shaped hole roughly the size of a golf ball (see pics below). Can I assume this is some type of insect damage and it likely killed the tree? On a few others that are still living I noticed some type of decay at the base where the trunk meets the ground. Does anyone spray any type of insecticide or fungicide or anything regularly on their trees? If so what? Also on a few dead standing trees, the bark has dropped off and the trunks are smooth with what looks like squiggly bug tracks or something. Thanks for the advice
/ Bugs killing my trees? #2
might be after the oak dies, here are some oak issues
Common Oak Tree Problems
Insects:
Galls
Scales
Aphids
Borers
Caterpillars
Lace bugs
Leaf miners
Twig pruner
Oak Tree Diseases:
Anthracnose
Powdery mildew
Root rot
Canker disease
Fungus
Bacterial Leaf Scorch
Leaf blister
Symptoms of Oak Tree Diseases & Pests:
Discolored or spotted foliage
Dead or dying foliage or branches
Thinning canopy
Shelf mushrooms
Wet patches on trunk
White coating
http://www.naswc.org/docs/oak_tree_diseases.pdf
tells you what to look for for each disease
/ Bugs killing my trees? #3
This last summer, being a new country guy, I was taken by surprise by all the freaking ants out here...along with other insectoids.:D
I did some insecticide research and really liked what I saw about Bifenthrin. It's long residual plus the fact that is doesn't play well with water...doesn't dilute easily...was all a plus for me.
I found that Orthos Home defense max concentrate had the highest percentage of Bifenthrin.
I mixed up some in my 30 gallon sprayer and sprayed the yard, the trees, the house...if it didn't move it got sprayed.
The ants weren't happy but the residual was crazy. Anything landing on the deck or air-conditioner went legs up even after a week after application.
/ Bugs killing my trees? #4
While you may have other problems that appears to be good old fashion rot. Being in the center it is really not that uncommon for rot to develop near the ground somewhat centrally located in the trunk. The list above however is a pretty complete list of common problems you will see. I have cut down nearly as many trees that were hollow in the center( or had the beginnings of being hollow like that one) as trees that were solid. If it were me I wouldn't loose too much sleep over it.
/ Bugs killing my trees? #5
I can only cover the basics, since my experience is in the west.
That pic looks like decay of the heartwood. The center of the tree is normally dead and decay of that wood doesn't hurt the tree except to make it weaker--and it takes a very large decayed area to make if significantly weaker and subject to breakage. Scrape around in there with a knife blade and it should be soft if decayed. It could be evidence of some kind of root disease I haven't seen, however.
Bugs kill trees in 2 ways, by defoliating them or girdling them. Defoliation once or twice generally doesn't kill a tree but weakens it's resistance to other insect attack or root disease. Other insects are generally bark beetles which burrow under the bark and girdle the tree. If bark beetles you should see little holes in the bark with their burrowing dust below the holes. If you pull off the bark you'll see their pathways and the pattern of the tracks is unique to each species of beetle.
Root diseases spread thru the air or into a healthy tree when one of it's roots growing thru the soil bumps into an infected root. Take an ax to a sick tree and scrape off some bark down near the ground. If it is a root disease you are likely to find fungal growth under the bark. If you don't find it low on the tree dig along the major roots, scraping off bark looking fungal growth. One of the most common root diseases that can infect almost any species is Armillaria and it produces clusters of honey colored mushrooms above the roots and a fan shaped white fungal growth under the bark. Search Google images for Armillaria for example pics. Armillaria attacks trees most often when the trees are stressed--drought, soil compaction, etc. But there are probably several other kinds of disease that could affect your oaks too. Root diseases can decay the roots and they kill the tree by killing the tissue beneath the bark which girdles the tree. Root diseases often affect trees in patches when the spread is root to root and the solution is often to cut all the affected trees including a buffer around the affected area and to switch to a different species. If it's a tree here and one over there situation, something else is going on.
I suppose there could be infections farther up the tree that could also girdle it, but I haven't seen any in my area. And if so, I would expect some species to sprout from the root collar below the infection.
I am not aware of any fungicide you could use.
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2021 KUBOTA KX033-4 EXCAVATOR (A62129)
2021 KUBOTA...
2007 Nissan Altima Sedan (A61569)
2007 Nissan Altima...
2025 John Deere 1025R (A62177)
2025 John Deere...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
