Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #21
Shipping container easiest. Although any building can be broken into. Container is most secure of three choices.Heat and condensation resolved by installing ventilation louvers. Add a solar power exhaust fan with thermostat control.
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #22
For me I would go the enclosed building route and throw a cheap insulation in there at some later time. (sooner if you put a metal roof on) It also keeps the rodents out which can be a problem with electrical wires sometimes.
Enclosed building or container you need to know how TALL your tractor is also. And if you can remember to fold it down every time you park it if you get a lower door entry. Now and "If or when" you decide to upgrade to a larger tractor?
A battery powered grinder or a bolt cutter has no preference'a for a padlock on a steel door or on a wooden door. It just keeps the lazy thieves out. Which is what you mostly want to do anyway, just make it hard enough for them to give up on yours and go to your neighbors?:rolleyes:
Ahh!! I was ignoring this fact.
That is a plastic building. Will crack in time.
Simple pole barn on dirt floor is cheaper way to cover equipment.
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #24
It took a century for the elements to just start causing a problem?
Are we sure this is a problem worth fixing?
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #25
1925 is the model, not the year.
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #26
I got a shipping container when critters chewed my tractor's diesel return line while it was sitting in a pole barn.
It's very wet here 4-5 months of the year, and hot in the summers. Get the container off the ground so that there's air circulation below and you won't have condensation issues (and make it high enough off the ground at least at one end so that fox or bobcat can patrol underneath and keep critters from living under it!).
My container is placed on a slight slope (also helps with water probably) so it the main entrance end where my tractor goes in is up on a railroad tie (with a gravel ramp going in) and the other end is on two railroad ties to be level. (Mine is a 40' with doors at both ends - makes getting stuff from the middle or other end much easier.) Containers only need to be supported at the corners.
My container is light tan and the temperature inside is typically about ten degrees (°F) higher inside during the sun than outside - not too bad.
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #27
Around here American Steel erects metal carports and garages very reasonably. They do not cover your area. It looks like these people do.
   / Budget-Friendly & Durable Parking Option for My Holland 1925 Tractor #28
I leave a tractor at our hunting land. I bought a used 13 x20 Shelter Logic frame from a neighbor for $25. Another neighbor gave me mismatched steel for free. The paint was the most expensive part of the build :oops:
(1) 12" X 14# X 120" (2) 12" X 14#, 167" I BEAM (A58375)
(1) 12" X 14# X...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
(50) UNUSED FUTURE 3'X12' CORRUGATED METAL SHEETS (A58376)
(50) UNUSED FUTURE...
Club Car Utility Cart (A55851)
Club Car Utility...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
