bucket toothbar
/ bucket toothbar #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Many readers will remember the discussion last summer about home-made tooth bars. Inspired by another poster, I found some combine teeth at TSC for about $5 each (each consisits of two German-forged steel teeth connected by a short crosspiece) and got a piece of 3/8" x 4" bar stock. Here're some photos showing the finally welded up bar, which works fine for digging in my hardened ground-up asphalt material pile that I use for road repairs. Considering my small bucket/tractor, I think they should be stout enough.
/ bucket toothbar #2
Second picture, from below.
/ bucket toothbar #3
I like them. I see business possibilities for you. /forums/images/graemlins/grin.gif
/ bucket toothbar #4
Wow, that looks like something out of a MAD MAX movie.....nice work!! /forums/images/graemlins/cool.gif
/ bucket toothbar #5
Good Job! That's the way I would have done it except I don't have a welder so I drilled two holes for each pair of teeth through the bar stock and the bucket and just bolted it on. Not very removable but I havent found a job yet I couldn't do with the tooth-bar on.
They are mean little shin (and anything else) catchers though! /forums/images/graemlins/blush.gif
/ bucket toothbar
A friend who welds more than I do used his $100 arc welder and a handfull of 6011 rods to stick it together. Low-tech.
/ bucket toothbar #8
seems like they will do the job, may take a few min. longer to remove or attach ,but what the heck.
/ bucket toothbar #9
Where abouts are you in northern MD, Varmit?
/ bucket toothbar
Roy- not too far from you, if you're in York Co.- down by Jacksonville- about 45 minutes from York, PA.
/ bucket toothbar #11
"Roy- not too far from you, if you're in York Co"
I'm in Windsor, bit SE of York...
I know Jacksonville...haven't been down that area for a while though.
/ bucket toothbar #12
Someone else did that a while back. Knowing how many I bust in rocks while combining or mowing alfalfa, I'm still not sold on their longjevity, but any farmer will have a bucketfull of good used ones (the sharp edge wears off & they are tossed) sitting around, instead of paying $5-10 a piece for the sickle guards. /forums/images/graemlins/smile.gif
--->Paul
/ bucket toothbar #13
</font><font color="blue" class="small">( .... instead of paying $5-10 a piece for the sickle guards. /forums/images/graemlins/smile.gif
)</font>
While you are here, Paul... I'm thinking to add a sickle bar cutter to the edge of my bucket. It will work then like a mow & collect (the grass in the bucket.) Very useful, isn't it? Now, the only left work is how to give the motion to the sickles there on the bucket edge. Lets hear the simplest idea.
/ bucket toothbar #14
Orbit (hydraulic) motor driving a wobble box.
A direct mechanical drive would be more efficient, but cost more & too many parts to get it plumbed through a loader - shafts & belts just won't make it.
Electric drive probnably isn't robust enough with 12v available.
Only leaves hyd.
--->Paul
/ bucket toothbar #16
Yes, Paul, hydraulic driver looks best option.
But, instead of a hyd. motor, I'm thinking about a simple hydraulic vibration system with a small piston on each end of sicklebar cutter. Anyways, since this sickle cutter will not be more than 3-4 ft (as it will be mounted on the bucket end) the power required to operate it will not be high. Also, the friction in this system will be less because it's not a mechanical friction. Worth to make such a system? Not sure yet. But certainy, worth to try. Will see.
/ bucket toothbar #17
I had thought about using those for a toothbar also. I was wondering since the 3/8 by 4" bar has to be bolted to the bucket anyway, could the teeth just be bolted to the bucket and forget the bar?
/ bucket toothbar
I had thought about that too, but it would have been 10 bolts, not 3 or 4, and more importantly, the teeth have slots cut in them to fit over (in my case) a 3/16" bar, and that slot needs to have some steel welded in it so as to not weaken the teeth, so you might as well do it right...
/ bucket toothbar #19
I stopped by a farm store and took a closer look at the teeth and you are right, the bar would add a lot of strength and probably save some wear and tear on the bucket edge. Thanks
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
John Deere 185 Hydro Riding Mower (A66285)
John Deere 185...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
