Bucket teeth and shanks
/ Bucket teeth and shanks #1
boats123
Wv
Ford 641 kubota m4900
I have a Bush Hog fel with a heavy duty bucket. I would like to make a toothbar but have been unable to find shanks that fit the edge of the bucket. It has a welded on cuting edge with a 10 degree cutting edge angle . I cannot find a shank with less than 20 degree angles on the cutting edge. Does anyone know who manufactures shanks that will fit the bucket. I have Fabco's book and have sent drawings to a couple of places but no luck. Who makes them for bush Hog. Went to John Deere dealer yesterday but no luck. Any help appreciated
Thanks
boats123
/ Bucket teeth and shanks #2
I have the same problem with JD3130 loader bucket. I going to try making my own. I picked the teeth from JD. I have made me a wooden pattern of what the shank needs to be.
My holdup is the 1 1/8" material. I make weekly trips to the scrap yard, I'm not in a rush, but if I don't find anything in a few weeks I just breakdown and buy new peice.
I'll post some pics when I get going.
JD
/ Bucket teeth and shanks #3
Try Ebay, gobs of bucket teeth I think from fabco, lots of sizes and styles. I got 9 for my 72" bucket for $90 on Ebay and picked up some 3/8"x2" flat bar along with a couple 4"x6"x3/8" plates locally. Total cost for a bomb proof tooth bar was about $125 with paint, two bolts, and a couple good hours in the shop. /forums/images/graemlins/smile.gif
/ Bucket teeth and shanks #4
boomer4snow,
You forgot the most important part! A picture or two! /forums/images/graemlins/grin.gif
I made a drawing and sent it to Fabco and they don't have anything. The John Deere Dealer has nothing and spent a considerable amount of time trying to locate some as JD makes a bucket with the same cutting edge so i don't know what to do now. The ones on E-Bay won't work and from their configuration I don't think i can cut and fit and make them work. will try Case and Cat next week. Thanks for the replies and Iwill post some photos when I go back to the farm which is 100 miles away from my home. Boats123
/ Bucket teeth and shanks #6
Have you thought about cutting sloped notches in the bar? If your bucket has a 10 degree edge, and your teeth have 20 degree edges, then cut or grind the bar down to match the 10 degree difference where each tooth goes. Once everything fits together, weld the heck out of it. Make those teeth become one with the bar.
/ Bucket teeth and shanks #7
You might want to try H&L out of Oklahoma. The make lots of small teeth and adapters, primarily for the RTB (Rubber Tire Backhoe) industry.
/ Bucket teeth and shanks #8
I too have a Bush Hog loader. I have tried the aftermarket tooth bars and they will not fit because because the cutting edge is too thick. If you come up with anything that will work, please post it here for the rest of us - thanks, Lewis
/ Bucket teeth and shanks #9
I think with an angle grinder and an arc welder you could make just about any tooth work.
I'm currently working on a project where the center tooth on my bar needed to be relocated. I used the angle grinder to cut the old welds, repositioned the tooth a couple of inches and put down several passes of bead. You can bridge a pretty good gap with a little patience.
/ Bucket teeth and shanks #10
I would like to thank everyone for their input, however after driving several hundred miles and having no luck I am about to give up and buy a bucket from my neighbor that has a toothbar on it. Thanks again for all of your input and suggestions,as always they have been informative and helpful.
Boats 123 /forums/images/graemlins/confused.gif
/ Bucket teeth and shanks #12
I finally found a tooth bar for my Bush Hog bucket - had it made to fit by Markham Welding in Denton, NC. Sent them the measurements and they made it in one day - $210. Lewis
/ Bucket teeth and shanks #13
Don't ask me why but when I seen the subject of this Thread I though it said "Buck Teeth, and Skanks"
You know it's been a long day when...... /forums/images/graemlins/grin.gif
/ Bucket teeth and shanks #14
A post on page 2 may help ,it is titled Yet another tooth bar.
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2022 EZ-GO ELITE...
