Bucket on tractor is lowering too slow
   / Bucket on tractor is lowering too slow #1
Baker
I have a 2000 Mahindra 2810. The bucket raises fine but it is extremely slow when trying to lower it. The 3pt hitch raises and lowers fine. Would appreciate some advice.
Kevin
   / Bucket on tractor is lowering too slow #2
Has it always done this. Maybe it has a restrictor in the circuit [ looks like a washer with a set orifice to control flow ]
Is there air in the cylinders?
Does the float mode work OK?
   / Bucket on tractor is lowering too slow #3
It has to be a problem with your joystick valve. When you raise the loader, fluid flows in the same lines as when you lower it, just in the opposite direction. That means your valve must not be opening properly when you move it to lower the bucket. I'd bet that if you reverse the hoses at the quick connect, you will also change the problem from lowering to raising. That would tell you it's the valve for sure.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
