Bucket on tractor is lowering too slow
   / Bucket on tractor is lowering too slow #1
Baker
I have a 2000 Mahindra 2810. The bucket raises fine but it is extremely slow when trying to lower it. The 3pt hitch raises and lowers fine. Would appreciate some advice.
Kevin
   / Bucket on tractor is lowering too slow #2
Has it always done this. Maybe it has a restrictor in the circuit [ looks like a washer with a set orifice to control flow ]
Is there air in the cylinders?
Does the float mode work OK?
   / Bucket on tractor is lowering too slow #3
It has to be a problem with your joystick valve. When you raise the loader, fluid flows in the same lines as when you lower it, just in the opposite direction. That means your valve must not be opening properly when you move it to lower the bucket. I'd bet that if you reverse the hoses at the quick connect, you will also change the problem from lowering to raising. That would tell you it's the valve for sure.
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
FAKE (A52472)
FAKE (A52472)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
