Bucket on tractor is lowering too slow
   / Bucket on tractor is lowering too slow #1
Baker
I have a 2000 Mahindra 2810. The bucket raises fine but it is extremely slow when trying to lower it. The 3pt hitch raises and lowers fine. Would appreciate some advice.
Kevin
   / Bucket on tractor is lowering too slow #2
Has it always done this. Maybe it has a restrictor in the circuit [ looks like a washer with a set orifice to control flow ]
Is there air in the cylinders?
Does the float mode work OK?
   / Bucket on tractor is lowering too slow #3
It has to be a problem with your joystick valve. When you raise the loader, fluid flows in the same lines as when you lower it, just in the opposite direction. That means your valve must not be opening properly when you move it to lower the bucket. I'd bet that if you reverse the hoses at the quick connect, you will also change the problem from lowering to raising. That would tell you it's the valve for sure.
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
