bucket not staying up
   / bucket not staying up #11
For clarification.....is it the "bucket" or the "loader arms"?
IE: is the bucket DUMPING itself over time.....or the whole loader just going down?
   / bucket not staying up #12
Happens to a lot of guys.
This was me making a funny, but also what I meant was a lot of people on here notice their loaders/buckets/backhoes drifting down kinda fast when not in use. Initially I thought mine did to, but now I'm of the opinion that it's fine, thanks to reading all the people here complaining about same.
   / bucket not staying up #13
My BX23 700 hrs drops faster as I load it with firewood, engine running at 2k or so.
Without loading the bucket and the engine running it drops down maybe an inch every 10 minutes or so. FWIW
   / bucket not staying up #14
An inch every 10 minutes with no load is pretty rapid. In inch every 10 minutes with max load wouldn’t be that bad. It doesn’t make any difference if the engine is running or not.
   / bucket not staying up #15
That's not right.. My Massey would drop a little overnight but not at all when in use, I could load the bucket with firewood, leave it up a couple of feet, go eat lunch and it wouldn't move..
   / bucket not staying up #16
An inch of bucket travel or an inch of rod travel in 10 minutes? I’ve seen drift specs written both ways. An inch of rod travel in 10 minutes would be within some manufacturers tolerance.
   / bucket not staying up #17
not the OP but having a similar issue with my L5740 previous to recent work the bucket stay and any position for weeks at a time. Now the bucket will got full dump if left suspended for more than 1 hr.
I disconnected the lines and it still happens so i am assuming a seal is leaking in the bucket cylinders. No visable leaks
This sound like the same as what happening whit my tractor
   / bucket not staying up #19
There is a simple test procedure which, if followed, will identify the source of the drifting down.
Dave M7040
  • Testing double acting cylinders.pdf
   / bucket not staying up #20
Dave M7040
Or you can use a non-contact infrared thermometer aimed at the area where the piston sits inside the cylinder bore. Cycling the cylinders either fully retracted or extended for short periods on/off starting with cold oil. If the piston area raises as little as 5* above the rest of the barrel, the piston seal is leaking. No mess, no spilled oil (until you rebuild the cylinder).
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2019 Elgin V2403-CR-T Broom Badger Sweeper, S/N V2903-7JV8496, Kubota Turbo Diesel Engine, 4,664 (A59076)
2019 Elgin...
HUM V (A58214)
HUM V (A58214)
