Bucket mounted limb cutter.
/ Bucket mounted limb cutter. #21
I wonder if something like this might work for you, especially for smaller limbs.
I suspect you might encounter problems orientating the blade on the limb with something attached to the bucket.
My (badly drawn - I'm no artist) rough sketch attached shows how I think I might approach such a project.
By having the sharpened hook on a pole you will have much more control as to where you place the cutting edge on the limb. It will also allow you better control to manoeuvre around branches that might be in the way of reaching the desired point on the limb you want to cut.
You can remain seated while positioning the hook.
Once you have the hook in place, back up the tractor and the limb will be cut.
All you need is a suitable place to anchor the end of the chain and a neat bracket to hold the pole when not in use. If the limbs are in the way of your mowing, I would assume they wouldn't be high, so the pole doesn't need to be long and can be easily stowed.
Ken
/ Bucket mounted limb cutter. #22
A pallet-puller like mechanism with an anvil cutter? "Anvil cutter" is as someone else mentioned, a single blade that cuts against an opposing anvil side (as suggested, blunt/anvil side would have a receiving depression to help steady the blade/cutter twist).
Pallet puller (I've got a similar one, but I've never used it- abandoned project!):
I will look at those ideas when I build it. Right now I'm looking at a thick blade sharpened on both sides so I can make a slice top and bottom then break the limb off with the bucket.
RSKY
/ Bucket mounted limb cutter. #24
Have miles of pasture, hayfields, roads bordering woods. Low limbs are a problem. Use bucket and grapples to break or shear them off. Now have found a piranha toothbar the best at grabbing limbs to break/shear them off.
/ Bucket mounted limb cutter. #25
Here ya go, 44" cutter,
Made by Trail Blazer Attachments...
SR
New Quick Attach Hay Spear (A65579)
New Quick Attach...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
JOHN DEERE 4230 TRACTOR (A64277)
JOHN DEERE 4230...
