Bucket mounted limb cutter.
   / Bucket mounted limb cutter. #11
J_J's Hydraulic limb snipper: http://www.tractorbynet.com/forums/attachments/141126-hydraulic-limb-snipper.html#post1635813
The top of the bucket is not as strong as the bottom edge even though I have reinforced it with 1/4" plate. So I may mount it on the bottom lit where there are already holes drilled. I don't want any hydraulics or complicated expensive equipment to use once every three or four years. Limbs up to a half inch or bigger can be ripped off with the bucket. I hope to make something that will saw off or weaken a larger limb enough that the bucket can break it off.
All in all I would probably have to walk more than a mile carrying my gas powered pole saw to trim everything. And all I want is to remove enough larger limbs so the renters can get closer to the edges when planting their crops or cutting the hay.
   / Bucket mounted limb cutter. #13
I seen one where a guy mounted a chain saw on about a 6 ft piece of 2x2 tubing, and a bracket for it to slide into on the side of his bucket. Had a string and a pulley to operate the throttle from the seat.
   / Bucket mounted limb cutter. #14
<Snip>Anyway it is time to mow the CRP land and I am needing something to cut limbs that have overgrown the fields on about 150 acres on four different farms. While I have used a pole saw to do this that was ten years ago and I am now 63 with a new knee.
Getting to the point. I want to mount some kind of blade in the receiver on top of the bucket so I can rest the blade on a limb, lower the loader to put weight on the blade, and back up to slice the limb off. I don't intend to use this on a foot diameter limb, but something an inch or two in diameter. What I'm planning now is to weld a sharpened old bush hog blade to a receiver and try that.
I am not going to spend more than thirty dollars on this project!!
Has anybody done this before? Did you have any luck?
The tractor I will use is small, Kioti CK20. Anybody think I am wasting my time?
<snip>
RSKY
Yes, your wasting your time to try and do it for $30.
Since you are cutting branches up to 2 inches in diameter a hedge trimmer won't do, you need a chain saw on a stick.
I just bought an Echo PPT 280 w/ 4 foot extension, 28CC engine, 4 chains, 12" blade for about $600. I can reach out to 17 feet and get limbs. And I've cut through 8" of limb like butter.
So why not carry your gas powered pole saw on your tractor?
Or for YOUR use it reads like you should be able to wield a Harbor Freight 1.5 HP ELECTRIC POLE SAW running off either a small generator OR an inverter off your tractor. The pole saw is on sale for $70. It reaches out to 8' 10" and standing on your tractor you should be able to trim up to 10 or 12 foot high with ease.
/edit - how high does your FEL reach?
I think dragoneggs does similar.
   / Bucket mounted limb cutter. #15
What about mounting a bracket on your FEL to sit a telescopic pruner in then operate it from the seat.
Amazon.com : Fiskars Power-Lever Extendable Pole Saw & Pruner (7-14 Feet) : Patio, Lawn & Garden
Or get a pair of ratcheting loppers a mount them on the bucket with some light chain back to a lever or something to actuate them.
Amazon.com : CHILI Tools 16-Inch Pro Bypass Ratchet Lopper For Thick Branches, Heavy Duty SK5 Teflon Blade Featuring Sturdy Nylon Fiber Handle, Made In Taiwan : Patio, Lawn & Garden
Or like the hydraulic tree shears others are talking about, make a manual one if you put a big enough lever on it it will be easy enough.
Just my thoughts on the situation.
   / Bucket mounted limb cutter. #16
If I had to do this, without a powered cutter, I would make maybe an 8ft boom of 2in square steel, with an old 3-5ft crosscut saw blade mounted with a limited pivot on the end of the boom. Put the blade over the limb, with the limb at the near end of the blade, lower it a bit, then back up till the blade comes out of the cut. Don't push the blade, only pull! Repeat if needed.
Bruce
   / Bucket mounted limb cutter. #17
Get you an old cross cut saw blade and mount it to the male part of a receiver hitch. Put that into your bucket mounted receiver hitch and trim away.
I considered the crosscut saw and backing up but I don't think it would hold up. That's why I want to push instead of pull. Also less strain on the bucket cylinders. About every three or four years I do the walk around with a pole saw deal and trim the field edges. That is a LOT of walking because I do it on both my mother's farms, my father-in-law's farm, and my oldest daughters ten acres. The only FEL we have is on the smallest tractor. Have called three or four places and can't find an old blade. May have to come up with something else.
RSKY
   / Bucket mounted limb cutter. #19
I mounted a bumper receiver on the top of the FEL bucket to put a trailer hitch. I can drive up and pick up the hitch on my trailers and move them around without getting off the tractor. For the past month I have used this to move around a 42' lift we were using to paint my daughter's house.... That is a story in itself! Anyway it is time to mow the CRP land and I am needing something to cut limbs that have overgrown the fields on about 150 acres on four different farms. While I have used a pole saw to do this that was ten years ago and I am now 63 with a new knee.
Any answers will be appreciated.
RSKY
My neighbor made him a simple one. Mounted it on long boom pole. Made some shear blades with hydraulic cylinder. Had problems with two opposing sharp blades. Finally made flat land on one with recess . this stopped his blade from bending. Similar to picture posted here. Check how large loopers are made. Very similar.
I'm not planning on anything that fancy. No hydraulics, just a sharpened blade I can put down pressure on and back up or drive forward and slice a limb off. Not going to use it for heavy duty land clearing, just a few limbs on the edge of fields I am mowing.
RSKY
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
19008 (A56859)
19008 (A56859)
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
