Bucket modifications
/ Bucket modifications #21
Don't have any ideas for you, except that you might get better results by starting a new thread specific to your situation.
Yes, and include some pictures.
/ Bucket modifications #22
Here is what I came up with, to deal with the same type of issue. We shovel out our horse stalls in to the bucket and dump on a pile around the other side of the barn. Made from a sheet of heavy aluminium about 1/4" thick, with a stiffener bolted to the leading edge, slotted angle on the sides, to attach 3/4" plywood. I drilled and tapped 2 holes per side and use 5/16" bolts with flat washers to hold it in place. I take it off when not in use, a cordless drill with nut driver bit makes it easy enough. I'm sure the bolt holes will strip some day, but works well enough for now. Been using it over a year.
Hope that helps...
To the guy with the MF 135 bucket issues... bottom pins of the bucket need spaced back some. Doing so will tilt the backet back more, but decrease dump angle. Will take fabrication and welding.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
Kubota Snow plow with subframe
Kubota Snow plow...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
