bucket lifting problems
   / bucket lifting problems #1
RogueFishr
Southern Oregon
Kioti CK30
I have a Kioti CK30, with a problem that is getting progressively worse. When I pull back on the stick, to raise the bucket with a load in it, it lowers. If I pull back more, it will finally reverse and raise the bucket. If I stop, the bucket will slowly lower itself. If I try to raise it again, it will drop rapidly until i pull the stick back far enough. Is this something in the control valve? Or is it a pump problem? It worked fine, until this summer, and has been getting progressively worse. I am trying to save some money by figuring out what this is and replacing / repairing it myself.
Thanks for any help.
RF
   / bucket lifting problems #2
RF
Your control valve need a check valve in "parallell gallery"....or maybe better said that you need a new control valve that have this check valve!!
see red circle on my picture of a basic hydraulic system
Thanks for the reply. I will look into getting a new check valve. I may take mine apart (once I know I can get a new one), and see how it works.
Thanks again,
RF
   / bucket lifting problems #4
OK, cool!^_^ I just wanted to make sure I didn't do anything wrong :]
Nice! I'll start saving up some scratch for this:eek:
   / bucket lifting problems #5
Thanks again,
RF
If there is a check valve in your controlvalve....not all control valves come with these check valves....this check valve will secure the load from dropping from gravity, when operating the control valve....for example a log splitter valve don't need this checkvalve because there is no load pressure from gravity, that tries to push flow backwards....
I don't know if your bucket function ever have been normal. If so there is a check valve in your control valve, and it is possible it have jammed in open position...
Can you send pictures of your control valve....these check valves are usually located under a plug between the ports.....
   / bucket lifting problems #6
I believe that just about all valves designed for loader work have internal check valves to keep the load from dropping when shifting the spools.
   / bucket lifting problems #7
Loader valve with load check valves
splitter valve, No load check valve
If a splitter valve is used on a loader, it will act like posted.....
John Deere Z930M (A50121)
John Deere Z930M...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
Informational Lot - Shipping (A52748)
Informational Lot...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Chevrolet...
