bucket level indicator paint on the rod
   / bucket level indicator paint on the rod #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
How do you get the mark to stick?
I'm considering taking mine off and milling a slot in it so the paint won't scrape away
   / bucket level indicator paint on the rod #2
My bucket rod is cut at same length as end of tube when bucket is level .... IF rod is poking out of tube bucket lip is up, if rod has disappeared into tube bucket lip is down....
dsc01708-3-jpg.675201
   / bucket level indicator paint on the rod #4
I took a dremel with a cutoff wheel and made a small groove in the rod then painted white. Did it 3 years ago still good
   / bucket level indicator paint on the rod #5
I had one put on my Deere when I bought it. I have yet to use it once. Eyeing the top of the bucket works for me.
Dave
   / bucket level indicator paint on the rod #6
I used wire shrink wrap. Works great.
   / bucket level indicator paint on the rod #7
I just know that "about an inch exposed" I'd level. For me, that's close enough
   / bucket level indicator paint on the rod #8
What I did was to file a flat spot so that a contrasting paint (used white paint) would not get rubbed off.
   / bucket level indicator paint on the rod #9
Your mailing a mark sounds the way to go. Two marks if needed. Paint can be applied, wiped off while leaving it in the milling. Different color of paint if needed.
   / bucket level indicator paint on the rod #10
I did the same with mine.
Just cut the rod off so level with the tube the bucket is level.
Works very well.
26120 (A56859)
26120 (A56859)
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2015 Forest River Rockwood Freedom Pop Up Trailer (A59231)
2015 Forest River...
Case 1083 20ft Corn Head (A56438)
Case 1083 20ft...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
