Bucket Hooks? Or clevis mounts instead?
/ Bucket Hooks? Or clevis mounts instead? #41
I started with a single grab hook welded in the center of the bucket on top. This worked great and as time went by I kept testing it. Well, I started clearing a lot with some good size oaks and in using the tractor as a skidder I bent the top of my bucket down about 3/8"; I had found it's limit. So I straightened the top (no easy chore) and then welded a d-ring inside the bucket to use for pulling. I have maxed that baby out a number of times. So I am a proponent of having both and having them welded. The d-ring is welded where the bucket has a support piece on the back.
Later, I wanted an easy on and off trailer hitch and found that d-ring to be very useful in that regard. The hitch is on or off in less than 30 seconds and does not move sideways at all.
Looks familiar. :)
Bolted through the cylinder mount reinforcement. And I have a large turnbuckle I use with a receiver on the edge, too. It is used mostly with a short boom pole, so it attaches to a chain near the tip of the pole.
Bruce
/ Bucket Hooks? Or clevis mounts instead? #42
That is very interesting.
/ Bucket Hooks? Or clevis mounts instead? #43
I've seen a good number of threads regarding bucket hooks but I rarely have seen any pic's of them in use. Are they only for lifting or can you lay a log in front of the bucket and wrap short chains in some rapid convenient fashion? I've just been going around the whole bucket.
I've dragged logs with mine several times. With some of the hills on my place I'd rather back up than try to drive up forward and drag a log behind. It's nice to be able to use the FEL to lift the end of the log too. Just lift the log, put a choker chain around it then hook the choker in the hook and drag away. Also chained big awkward stumps to keep them in the bucket while hauling.
/ Bucket Hooks? Or clevis mounts instead? #44
Isn't that an interesting application. I could see how that would work.. :thumbsup:
/ Bucket Hooks? Or clevis mounts instead? #45
I tighten that turnbuckle (2200# work load) with my hands; no tool is needed.
/ Bucket Hooks? Or clevis mounts instead? #46
You can also use it to an extent to pull small trees out of the ground by running the chain around the small tree several turns leaving each end with enough slack to reach both of your bucket hooks. Curl and lift your bucket as the chains tighten up on the trunk. If your tractor is able, the tree will pop out of the ground.
Exactly. You can do the same thing if you need to remove a fence. Drape the chain over the T-post, curl and lift. You can do a whole bunch without getting out of your seat.
/ Bucket Hooks? Or clevis mounts instead? #47
IMG_0737.JPGIMG_0738.JPG I have two hooks welded on inline with cylinders and added trailer receiver hitch in center of bucket. It is the red part in the center usually I have my gooseneck ball and 10,000 lb hook for lifting in the hitch but I have several different things that will fit. Tri-ball d-ring ect.
/ Bucket Hooks? Or clevis mounts instead? #48
I use these welded on to a 4" square 1/4" plate.
/ Bucket Hooks? Or clevis mounts instead? #49
And this welded to the top of the bucket. I use a 5" drop ball to move my trailer around where the truck is too big.
/ Bucket Hooks? Or clevis mounts instead? #50
Thank you.. I am relatively proud of that 7018 weld at 125 amps with my little Everlast PA160. It must have caught the eye of others as well, because a "professional" welder in Florida stole the photo and put it on his website as an example of his work. That "pissed" me off considerably and I sent his some electronic hatemail to which he basically told me where I could go. It was brought to my attention by another member no longer active, and he gave him a piece of his mind too, but the "pro" did not really care. If you look carefully you can see the little brick retaining wall by my house where a lot of my photos are taken, as that is where I work on my tractor. In my opinion my weld with the stick is a better weld than the Korean fella did with the MIG on the plate on top of the bucket. Here is a photo of the welder that made it.
View attachment 488544View attachment 488545View attachment 488546
You might want to watermark and copyright future photos. Also share the photo thieves web site / email so others can nag him to take the stolen photos down.
/ Bucket Hooks? Or clevis mounts instead? #51
James, although I'll concede that there are differences in the various brands of welders and Everlast is well known for excellent quality,,,, the quality of your hook welds is much more due to the person holding the welder stick than the machine sitting nearby. :cool:
I will agree with that. There is a guy here that has cr@p equipment and can turn out stack-'o-dime welds so good they bring a tear to your eye. (y)
On the other hand, I have great equipment but my welds bring a chuckle to the crowd. ;)
/ Bucket Hooks? Or clevis mounts instead? #52
Wow, is that a beautiful looking and functional weld.
Well, a good 7018 rod and a DC welder set at about 125 amps is hard to beat.
/ Bucket Hooks? Or clevis mounts instead? #53
Side discussion based on your comment . . . How do you watermark and copyright photos? Is that just a filter that you add using picture editing software and then save it?? Thanks.
/ Bucket Hooks? Or clevis mounts instead? #54
Try google search "how to watermark graphics"...
I sometimes just use something like Microsoft Paint or Irfanview to add text to graphics.... Just need to put it someplace its difficult to edit out without destroying graphic...
Example original image...
Marked image...
Text can be anything like "DLM Copyrighted 2021" or "Copyright by DLM Oct. 27-2021" or just as in example picture...
And there is this...
/ Bucket Hooks? Or clevis mounts instead? #55
Bucket Hooks? Or clevis mounts?
If you're gonna do bolt-on, like Kenny's, might as well get the clevis mounts to be the backing plate. Gives you more options at minimal cost, so why not?
/ Bucket Hooks? Or clevis mounts instead? #56
Just saw this article, though I myself have not tried these.
/ Bucket Hooks? Or clevis mounts instead? #57
I measured the top of the RK37 bucket and I think it is only 2 inches wide and 1/8 inch thick. There is a 2 inch wide, 1/4 inch thick bar as backing but it is a couple inches below the top. The bucket top bends to a 2.5 inch flat section and then curls again inside for a short distance, basically an open tube.
I see that most of the bolt on 5/16" hook bases are 3.25 inches wide.
Any suggestions for mounting bold on hooks besides on the sides of the bucket?
/ Bucket Hooks? Or clevis mounts instead? #58
Our hooks are only 2-5/8" deep, all the "copies" are deeper. Some guys mount them on the back wall like this:
2018 Toyota Tacoma Pickup Truck, VIN # 5TFRX5GN2JX129061 (A61165)
2018 Toyota Tacoma...
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
Freightliner Columbia (A63118)
Freightliner...
3PC. GALVANIZED HAY RING (A62130)
3PC. GALVANIZED...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
