Bucket Hooks? Or clevis mounts instead?
/ Bucket Hooks? Or clevis mounts instead?
Wow! Many thanks to everyone for all the great ideas!
/ Bucket Hooks? Or clevis mounts instead? #22
My approach was a sturdy bolt-on angle with slots. I like to weld (made the cab) but this is something I did with the first Kubota and it served well for ten years on that one. It has always been up to the task. Works with the chains toward the front or rear of the bucket. The picture of the 6' Landpride deck hanging out there gives some indication of the strength. That hookup made it easy to tuck the deck under a shelf for the winter. Works with any chain up to 3/8".
/ Bucket Hooks? Or clevis mounts instead? #23
Richard, you are shattering my illusions! I got an Everlast so my welds would look like that! You mean my first ever weld isn't going to be that good? :eek:
We shall see..... :)
/ Bucket Hooks? Or clevis mounts instead? #24
I did both clevis mounts and hooks on mine, that way I can use whatever method is most convenient or applicable.
/ Bucket Hooks? Or clevis mounts instead? #25
I think I might have welded my hooks on, if my welds looked anything like yours James. As it is, mine are bolted on.
/ Bucket Hooks? Or clevis mounts instead? #26
In the interest of full disclosure, and it hurts me to say this, but ALL of my welds do not always look so good. There, I said it and it is true. Dadgummit. It requires concentration, and proper prep to make a weld that looks decent, and sometimes I fail on both counts. :eek:
/ Bucket Hooks? Or clevis mounts instead? #27
My approach was a sturdy bolt-on angle with slots. ---------
I agree with chim on chain slots. :thumbsup:
Cut slots into the bottom channel iron on the fork frame and in the pin on mounts of the brush fork frame.
Also added a receiver hitch in the center.
/ Bucket Hooks? Or clevis mounts instead? #28
Patience is my failure of choice......
/ Bucket Hooks? Or clevis mounts instead? #29
I hated having to choose one or the other, so...
This is a 1666 pound WLL D-ring, with a 5/16 clevis grab hook. It is bolted through the top of the cylinder mount for reinforcement. I use 5/16 and 1/4 GR70 chains. The 1/4 chains have 5/16 hooks. The 5/16 chain hooks will hook on the D-ring if needed, and the hanging hook will grab either size chain. This is in the center of a BX bucket. If I need a 2-point lift, I swing the chain over two of the toothbar teeth, inverted V fashion.
Normally I would have the bucket dumped when lifting, but with the cutter, I lifted it up, then pulled the trailer out from under. I needed the extra reach of the level bucket to get past the fender.
Bruce
/ Bucket Hooks? Or clevis mounts instead? #30
I welded chain hooks on the Allied bucket fitted to the Hurlimann. There are times I could use a clevis with rope and straps. And there are times when a chain plate would be handy (bidirectional).
If I were to do it over, I would do a chain plate with a drilled hole for a clevis. The weld on chain hook is a limitation.
/ Bucket Hooks? Or clevis mounts instead? #31
I think everybody eventually puts hooks on their tractor buckets. The question is what is the best way to do it?
The simple approach is to just weld on a couple of grab-hooks, directly to the bucket in the desired locations. An alternate would be to weld on clevis-mounts, which would allow you to attach most anything that used a clevis-pin connection.
Do you have any thoughts as to the pros and cons of either approach?
I have one hook and one clevis or a shackle mount right next to it in the center of my bucket. The dealer welded D rings on as standard but I asked for a clevis mount instead. It's much easier to attach straps etc. with a screw pin clevis but the hook is much better when working with chains.
/ Bucket Hooks? Or clevis mounts instead? #32
I've seen a good number of threads regarding bucket hooks but I rarely have seen any pic's of them in use. Are they only for lifting or can you lay a log in front of the bucket and wrap short chains in some rapid convenient fashion? I've just been going around the whole bucket.
/ Bucket Hooks? Or clevis mounts instead? #33
You could do it for a log, but it is very convenient to use chains for a rock too big to fit in your bucket. Just put it in the bucket as much as will fit, and then run a chain from one hook to around the front of the rock and slip the chain into the other hook. As you lift the chain will tighten up as the rock starts to fall out but can't now due to the chain around it. You can also use it to an extent to pull small trees out of the ground by running the chain around the small tree several turns leaving each end with enough slack to reach both of your bucket hooks. Curl and lift your bucket as the chains tighten up on the trunk. If your tractor is able, the tree will pop out of the ground.
I sometimes use a chain and a bucket hook to repel down a steep embankment to get down to clean out a culvert at the bottom. The chain makes it safe to go down and come back up. You can also wrap a chain around any object you can get it around and use it to lift it.
/ Bucket Hooks? Or clevis mounts instead? #34
My most frequent use is lifting odd objects.
/ Bucket Hooks? Or clevis mounts instead? #35
We have over 100 different pics on our website-in the Gallery and on the User Comments page showing hooks in use.
Here is a great example for brush:
Lay the chains on the ground, attach one end to the hooks or shackles:
Start piling in sticks and other brush:
Then pull the loose end back to the hooks to secure load, sorry no picture of that.
How about holding a big rock in the bucket:
Here are some log pics:
/ Bucket Hooks? Or clevis mounts instead? #36
I couldn't find my pictures but they surely look like what Kenny posted. I started by just wrapping the bucket but they can slip off and are more trouble to adjust having the extra hooks allows you to quickly make the chain the size you need and just toss the excess length where convenient.
/ Bucket Hooks? Or clevis mounts instead? #37
Maybe kennyd will start making the bidirectional chain slots. :thumbsup:
/ Bucket Hooks? Or clevis mounts instead? #38
A bolt on plate with slots cut in it??
Anyone want those I'll build em for ya, any size you want, any bolt pattern. Or,,,,,, go to your nearest metal shop and have them cut you some. :)
/ Bucket Hooks? Or clevis mounts instead? #39
Definitely have to have hooks on the bucket. I went with 2 weld on hooks lined up with the cylinders and an excavator hook in the center like all of our heavy equipment has to be able to use cables, slings, or chains.
/ Bucket Hooks? Or clevis mounts instead? #40
I started with a single grab hook welded in the center of the bucket on top. This worked great and as time went by I kept testing it. Well, I started clearing a lot with some good size oaks and in using the tractor as a skidder I bent the top of my bucket down about 3/8"; I had found it's limit. So I straightened the top (no easy chore) and then welded a d-ring inside the bucket to use for pulling. I have maxed that baby out a number of times. So I am a proponent of having both and having them welded. The d-ring is welded where the bucket has a support piece on the back.
Later, I wanted an easy on and off trailer hitch and found that d-ring to be very useful in that regard. The hitch is on or off in less than 30 seconds and does not move sideways at all.
