bucket forks
/ bucket forks #1
Calhoun Louisiana
Kubota L3430
I have a friend who simply drilled 4 5/8" holes in his bucket and then bolts his forks to his bucket when he needs them. They are made out of a staight piece of 1 1/2" by 4" C channel. What are the drawbacks to this arrangement?
/ bucket forks #2
C channel isn't all that strong - if you hook a pretty hefty load way out on the ends.
The bucket itself might not be all that strong, and can warp if you drill the holes fairly close together & put some real weight on the forks.
They are not adjustable for width - unless you drill a lot of holes. /forums/images/graemlins/smile.gif
But, it sure works fine if you know what you want and don't need industrial durability & strength.
--->Paul
/ bucket forks #3
Here are the tines I have had on 3 different tractors over the past 18 years. Ford1210 Cub7234 and Dk 35. They are attached by a 3/8 bolt loose so as I slide under a log or what ever they find their own way. 4x1-1/4x 3/16 channel out of the junk yard. I have hung a big v-8 engine out on the end of one and loaded it in a van.[very slowly] They are about 14" from the sides. bcs
/ bucket forks
how much do you think that engine weighed? Would the C channel pick up a pallet of stone that weighed 1000 lbs? If your Hook that hooks on the bucket were a little longer/wider wouldn't it distribute the load onto the bucket a little better?
/ bucket forks #5
Not sure of the weight of the engine. If I built another set I would go with 4x1 1/2 x 1/4. The original cutting edge on this tractor was 3x3/8, I added 8x1/2 to it and added 1/4 side pieces. Where the strain comes on this set up is the cutting edge. The buckets on all the tractors I looked at in this range were not built to rugged. I'm not sure my tractor can pick a thousand pounds. I haven't had it long enough to test it. bcs
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
