Bucket Driveway Edger Attachment
/ Bucket Driveway Edger Attachment
Not into straight lines in the yard. I like to sculpt my landscape :)
It maneuvers well, but I found that I had to make a couple of passes in a few spots. When going around curves it requires a little finess, but it does a great job in no time. Once we got all of the excess grass removed we can use the bucket edger to cut through the new growth horizontal root runners and then apply Kills All without effecting the desirable wanted grass.
/ Bucket Driveway Edger Attachment #23
I agree with Mace. a coulter off of a plow would work much better if anyone else were to build one. Inspector, you did well in building yours but I think it can be improved. A plow coulter mounted on a piece of heavy channel mounted on the lip of your bucket would pivot on curves and would be easy on and off if mounted like a ratchet rake. Ed :2cents:
/ Bucket Driveway Edger Attachment #24
Ed,
Agreed. Since it's not necessary to cut all that deep for an edger, it would also be doable to use a old saw blade as the cutter wheel, 7.5 to 12" or so, mounted to the forks, or weld additional fork arm length to the forks of a castering wheel.
/ Bucket Driveway Edger Attachment #25
Ed,
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2022 EZ-GO ELITE...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
Wooden Plant Holder (A64557)
Wooden Plant...
MAN BASKET (A64553)
MAN BASKET (A64553)
