Bucket does not rotate:
/ Bucket does not rotate: #1
Crutches
North Florida
Kubota L3600
I just replaced the four hydraulic hoses on each side of the bucket on my Kubota L3600. I replaced the hydraulic fluid that I lost. The boom raises and lowers perfectly but the bucket will not rotate. I replaced the hoses to same fitting as I took off one side at a time and replace them in the same order of the opposite side. There was nothing wrong prior to changing the lines. Help, I am new at this!
/ Bucket does not rotate: #2
I'm assuming that you are having trouble curling your bucket. I would disconnect and then reconnect the two quick connects that control curl. Something just as simple as a QD that is not properly seated may take care of your problem quickly.
/ Bucket does not rotate: #3
There could be a lot of air in the line, air in a hydraulic line doesn't move a bucket.
I will give it a try. I cannot imagine what I did wrong. I worked on Harleys at a dealership until last October. Then I was paralyzed in an accident and this tractor has replaced my motorcycle. I love it but I have a lot to learn.
Hey Pine Ride;
I don't know the technical term for your recommendation but I will just call it magic. I did what you said and it worked perfectly. I love this web site, it is better than a service manual. Thanks for the advice, I appreciate your help.
/ Bucket does not rotate: #6
Way to go Pine Ride, your a genius, sorry, I just couldn't resist. /forums/images/graemlins/grin.gif No fools no fun /forums/images/graemlins/confused.gif
Steve
/ Bucket does not rotate: #8
Bravo PineRidge. Yep, TBN has helped me a bunch in figuring out how all this equipment works, and all the uses I never would have known about otherwise.
/ Bucket does not rotate: #9
mike are you still BLUSHING? /forums/images/graemlins/grin.gif
/ Bucket does not rotate: #10
Frank while I like to help wherever I can it's most unusual to come up with the right answer the first time around. In this case we'll just say it was more luck than anything else.......
2025 Hercules 14 Gun Safe (A61569)
2025 Hercules 14...
Street Sweeper (A60352)
Street Sweeper...
2014 Ford Econoline Van, VIN # 1FDEE3FL6EDB17703 (A61165)
2014 Ford...
2014 Wacker Neuson ST45 Compact Track Loader Skid Steer (A61567)
2014 Wacker Neuson...
2022 John Deere 317G Compact Track Loader Skid Steer (A61567)
2022 John Deere...
2007 Volvo C70 Coupe (A61569)
2007 Volvo C70...
