Loader Bucket Cylinder Guard
   / Bucket Cylinder Guard #1
TonyF
Huntsville AL
BX200D w/FEL, B21 TLB, KX91-3SS. F700 Dump Truck
Anyone ever add a grill guard like frame to protect the loader bucket cylinders from logs and other large gunk from damaging the curl cylinders? If so how did it work? You see these frames on mulchers and specialty buckets.
I have a B21 that I been using to clear land, some of the trees felled are good size and dragging them to and stacking them on the pile more often than not causes them to slip and move around.
Thanks
Tony
Ok, no takers. Its good to be first I guess. Here's what I built.
I ran out of 'bota paint, have to get some more next time I'm at the dealer.
Tony
   / Bucket Cylinder Guard #3
Excellent Job... Looks good... :thumbsup: Would have saved me from having that dent in my hood :eek:
   / Bucket Cylinder Guard #4
That's a pretty good idea. I see them on dozers sometimes.
I have a 4in1 bucket and do the same thing in theory...I open it up wide and the top portion helps to push and adds that extra protection, too.
   / Bucket Cylinder Guard #5
That was one of the first things that we did to my little Case 310. Really works great when brushing. :thumbsup:
   / Bucket Cylinder Guard #6
Brian...Your Case looks great! That's a 6 way blade?
   / Bucket Cylinder Guard #7
Thanks, I finished a refurb on it last year and yes that is a 6 way blade.
   / Bucket Cylinder Guard #8
Sharp looking job..the little things can save a lot.
   / Bucket Cylinder Guard #9
Adding a guard to the FEL was the first mod I made to the tractor. Really comes in handy for moving stuff. Add a pair of clamp on forks and I can move an entire brush pile to the chipper.
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle All-Terrain Crane Truck (A55973)
2013 Peterbilt 367...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2008 Ford F-250...
