Bucket control problem
/ Bucket control problem #1
Chucksteak
I have a 2005 TC40DA. All of a sudden my bucket wont lift without playing with the control. I pulled the control valve and everything appears ok...no broken spools or missing parts. I can hear fluid blowing by ..Help !
/ Bucket control problem #2
Check your quick disconnects to make sure one isn't partially disconnected.
Bill
I checked those...seemed to be ok .. The fluid is rolling by the raise /Lower part of the valve and you can hear it.
..If I play with the handle I can get it to raise even with a load..but the only way to drop it is in full float.
The valve is very clean and free from any scoring or cracked spool rods...very puzzling ..curl works fine
/ Bucket control problem #4
Most spools have load checks, and are used when shifting positions, and keep the load from dropping. Check those out. The reason you can drop the load in float, is that the float position connects all ports to tank.
If you had a hydraulic gage, you could solve just about all the hydraulic problems.
If the valve has a relief valve, check that also.
(1) UNUSED 10-16.5 TIRE W/6 LUG RIM (A62130)
(1) UNUSED 10-16.5...
2009 Vanguard National Dry Van Trailer, VIN # 5V8VA53259M900716 (A61165)
2009 Vanguard...
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
2025 Ram 4500 Mechanic/Service Truck, VIN # 3C7WRKAL6SG570509 (A61165)
2025 Ram 4500...
2021 FREIGHTLINER M2 106 S/A 4X2 24FT BOX TRUCK (A59909)
2021 FREIGHTLINER...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
