BTX24 mid PTO generator drive question
   / BTX24 mid PTO generator drive question
Well Soundguy you missed a key point:) I don't want to have to remove the backhoe to run off the back PTO:cool: Hence the need to slide something under the tractor and run off the mid-PTO, haven't seen a commercial unit to do that. But you are correct in the cost will be close to Northern's rear PTO drive unit for materials...the fabbing labor I consider fun ;)
Dieznutz- agreed there will be some power loss stepping the speed up 2X...but then consider what must be lost on the rear PTO units that step it up a little more than 6X :eek:
Volfantz- both switches on my BX24 are plunger switches...holding them both down by hand allows the mid-PTO to be engaged.
   / BTX24 mid PTO generator drive question #22
I also am intrigued by the possibility of a mid PTO driven generator. Has anyone checked this company out?
http://www.raventechpower.com/documents/SupplementPTODrive106.pdf
They claim that their generator voltage and frequency output is stable over a WIDE range of drive speeds. This sounds ideal for a tractor driven setup where it would be difficult to precisely control the drive speed.
   / BTX24 mid PTO generator drive question #23
This is a close setup of what you're looking for on a BX24. All we need to do is use something close to what adlertom has found (& make it waterproof) instead of the hydraulic pump.
   / BTX24 mid PTO generator drive question #24
Nevermind....I just learned that the MSRP for this unit is $8,665
377811 (A48836)
377811 (A48836)
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2013 Hyundai Azera (A50324)
2013 Hyundai Azera...
KARCHER PRESSURE WASHER (A51244)
KARCHER PRESSURE...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
TMA (A49461)
TMA (A49461)
