BTX24 mid PTO generator drive question
   / BTX24 mid PTO generator drive question
Well Soundguy you missed a key point:) I don't want to have to remove the backhoe to run off the back PTO:cool: Hence the need to slide something under the tractor and run off the mid-PTO, haven't seen a commercial unit to do that. But you are correct in the cost will be close to Northern's rear PTO drive unit for materials...the fabbing labor I consider fun ;)
Dieznutz- agreed there will be some power loss stepping the speed up 2X...but then consider what must be lost on the rear PTO units that step it up a little more than 6X :eek:
Volfantz- both switches on my BX24 are plunger switches...holding them both down by hand allows the mid-PTO to be engaged.
   / BTX24 mid PTO generator drive question #22
I also am intrigued by the possibility of a mid PTO driven generator. Has anyone checked this company out?
http://www.raventechpower.com/documents/SupplementPTODrive106.pdf
They claim that their generator voltage and frequency output is stable over a WIDE range of drive speeds. This sounds ideal for a tractor driven setup where it would be difficult to precisely control the drive speed.
   / BTX24 mid PTO generator drive question #23
This is a close setup of what you're looking for on a BX24. All we need to do is use something close to what adlertom has found (& make it waterproof) instead of the hydraulic pump.
   / BTX24 mid PTO generator drive question #24
Nevermind....I just learned that the MSRP for this unit is $8,665
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
John Deere 960 Culitivator (A50514)
John Deere 960...
