Brutal tractor accident
/ Brutal tractor accident #2
not sure i believe the first picture is actually of this particular accident. tractor rims look to be a different color,
and the ground below is not the same as where the accident happened.
the 2nd pic sure, could be from that accident with the semi behind it.
either way it's a scary accident.
/ Brutal tractor accident #3
Those look more a truck rim and tire in the first image. I'd have no reason to doubt it is all from the same incident.
Friend of mine showed me a nice trick when pulling with cables like that, hopefully someone who sees this will prepare and be safer. Take a couple chains and lay out straight along side the cable you are pulling with. Use some quick links, carabiners, zip ties, twine, whatever... just hang the chain from the cable loosely every foot or so, and try to do it the full length of the cable, but at a minimum on both ends. Once you are pulling, if the cable snaps, the weight of the chain and the freeplay in the attachment of the chain keep it from flying around. Of course you want to size your chains accordingly as a light swingset chain wouldn't help much of anything, those guys needed some good heavy logging chains hanging from that cable to prevent that.
A heavy rope wrapped around a chain and tied loose on each vehicle will keep a chain from popping and flying when pulling too.
The key to pulling safely is never pull with anything you don't want flying at you, and if you don't want it flying at you, secure it from flying if it breaks.
I feel bad for his family...
/ Brutal tractor accident #4
Little did he know his fate when he work up that morning. Terrible!
I've broken a lot of chains, never a cable, because I don't use them much, but have never actually seen a chain breaking, present any sort of hazard, as in leaping into the air when attached to a drawbar.
/ Brutal tractor accident #5
Two minutes before the pull if you had stood there and suggested improvements . They would have told you to go away and mind your own business. Much like the people here that insist that they can work safe since they are using common sense and experience to compensate so substandard equipment and techniques.
/ Brutal tractor accident #6
Fortunately, I've not actually seen either a chain or a cable break, but when I was a volunteer fire fighter, we had a grass fire to put out one day that resulted from one truck trying to pull another truck with a chain that broke. And when it broke, it struck sparks off a big rock that started the fire. At least that's what the owner of the trucks said, and I think he was telling the truth.
/ Brutal tractor accident #7
I've seen chains break and fly. Thankfully from a distance. Typically it's the result of an idiot jerking on it rather than pulling...
/ Brutal tractor accident #8
Your friend is right about how to stop a cable or chain from turning into a whip when it breaks. When I was young I had a 4X4 truck and me and my friends would go mud bogging till one of us got stuck. We came across some guys that were stuck ahead of us, we offered to help and one of us used a 1973 4X4 GMC Suburban with a chain. Hooked the chain to the front of the GMC and the back of the Ford. The GMC backs up fast, the chain breaks and hits a guy standing next to the Ford and breaks his leg, bad. I take the guy to the hospital because my truck was at the back of the line. He lived, but we all learned a lesson that day. I wrap a chain around cables when I use my warn winch with a long remote switch. I'm sorry that poor soul died the way he did and I feel for his family.
/ Brutal tractor accident #9
I guess I lucked out.
Had a U-Haul car tow dolly lose a wheel. The guy who came to recover it hooked it up to a cable and winch to tow it up on his flatbed.
As the winch pulled on it the chain snapped and FORCEFULLY hit the back of his truck. We were both standing off to the side a bit but well within striking range.
I was always taught to throw something over anything you were pulling with. Like another rope, a boat, a floor mat, just something to prevent the "snap back".
/ Brutal tractor accident #10
I call it BS.......
That cab would be drench in blood.
/ Brutal tractor accident #11
A friend of mine grew up on a potato farm. He told me that one day he was in the cab-over dump truck pulling a broken-down semi down the road with a logging chain. He was looking in the driver's side mirror when the chain snapped. It took the mirror off the side of the truck, wrecked some of the cab at the back, and blew a big hole in the front fender. The story has always made me wary of cables/chains under tension.
I was always told to toss a floor mat or heavy rug or something over the middle of tow straps and such. With a cable under that much tension, you'd have to hook something really heavy on the middle.
/ Brutal tractor accident #12
I've told this before but it's worth telling again...
A couple of years ago a well respected local man was pulling some trees/stumps/whatever, possibly cleaning up a fence row, on his farm with a bulldozer. He was working alone on this particular day. After some time the family decided he should've been back home already and went to see what was going on. I don't remember all the details but what ever he had been using to pull the trees had failed and snapped back into the operator area. Sadly, those were the last trees he ever got to pull.
/ Brutal tractor accident #13
I was always told to drape something similar to you, jackets or even towels will supposedly work too. I refuse to stand alongside a tight cable or chain under load.
/ Brutal tractor accident #14
When I was a co-op the lab I was working in was doing some tensile tests on high tensile cable. The cable we were testing to failure was going to bring our very large tensile testing machine near its limit. All precautions were taken to keep shrapnel from flying out of the tester. When the cable broke at I think upwards of 200,000 lbs the cable slipped through the upper jaw and shot through the roof. Moral of the story is be very careful with stored energy, very bad things can happen when it is released.
/ Brutal tractor accident #17
Good catch Mace.
It was pointed out in the myriad comments on Liveleak; I had nothing to do with the actual finding that it wasn't part of the original video and the video is important enough on it's own. It bugs me when some fool inserts non related information into anything.
/ Brutal tractor accident #18
Dang...indeed a shame.
Man in our home town lost leg standing to close when the cable snap.
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
Copper Eagle Weathervane (A65583)
Copper Eagle...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
