Oil & Fuel brushog gearbox oil
   / brushog gearbox oil #11
this may be premature, but if you DO start finding a significant oil drop, there is a pretty great solution to replacing all the seals and whatnot. I have an early 80s Woods bushhog and it wouldn't hold oil for a moment without it all spinning out and leaking out of the gearbox. I replaced the heavy gear oil with "Corn-head grease" from JD and it has been working great for the past 8 years or so. Too solid to leak out, but liquid enough when in use to keep everything cool. No reason to do it if your seals are fine, but it is definitely a cheap solution if that ever comes up. Which now that I've typed all that, I'm sure it won't.
Also, I'm on board with checking before use!
207273 (A52708)
207273 (A52708)
Off-Road Hunting Buggy (A57148)
Off-Road Hunting...
ELECTRIC CENTRIFUGAL PUMP (A58216)
ELECTRIC...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
Bucket Pallet Forks (A57454)
Bucket Pallet...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
