Oil & Fuel brushog gearbox oil
   / brushog gearbox oil #11
this may be premature, but if you DO start finding a significant oil drop, there is a pretty great solution to replacing all the seals and whatnot. I have an early 80s Woods bushhog and it wouldn't hold oil for a moment without it all spinning out and leaking out of the gearbox. I replaced the heavy gear oil with "Corn-head grease" from JD and it has been working great for the past 8 years or so. Too solid to leak out, but liquid enough when in use to keep everything cool. No reason to do it if your seals are fine, but it is definitely a cheap solution if that ever comes up. Which now that I've typed all that, I'm sure it won't.
Also, I'm on board with checking before use!
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
KMC 4R TOOLBAR (A52708)
KMC 4R TOOLBAR...
1988 TIMPTE 40' ALUMINUM HOPPER BOTTOM TRAILER (A52708)
1988 TIMPTE 40'...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
