Oil & Fuel brushog gearbox oil
   / brushog gearbox oil #1
islandguy8
hilton head s.c.
mahindra max 28
this might be a stupid question but when is the best time to check the gearbox oil on a brushog. my manual says it cant be accurately checked until 15 to 20 min of operation. it has a small check plug that I remove to check level. but after operating and heating up wouldn't fluid come out because of heat and pressure, I figured to check it cold would be better? thanks for any info, this is my first tractor.
   / brushog gearbox oil #2
I always check mine before each use but,this may not be the correct way. I never really given it much thought.
   / brushog gearbox oil #3
Either way. Heat affects level ~ nil. Oil flows better when warmed but the level should be at or just below the hole. If it flows out a little when you open the hole, its full. ... If it doesnt, stick a small allen in thru the hole and turn it down. If it doesnt reach the oil youre low.
larry
thanks for the reply. i'll just check it before each use, its easy enough to do.
   / brushog gearbox oil #5
:confused:
It may be off the wall...but IMO if the "check plug" is gravity based...operating the cutter/gear box would distribute oil and coat all the internal parts...and a gravity based indicator would show slightly less oil than if none had been distributed...?
IMO, IF it is a gravity based "check plug"...It would make more sense to me if the manual said to WAIT 15-20 minutes AFTER operating to get an accurate reading...
   / brushog gearbox oil #6
The fill plug on my Woods mower has a cotter key to keep vent open to prevent any pressure buildup in gear case.
   / brushog gearbox oil #7
I would believe checking the oil before use is a good SOP. If the seal was damaged and the oil has leaked out from the last use... using it without oil is worse than the slight level difference between hot & cold gearbox.
That said ... I only have checked the level every couple of years.
   / brushog gearbox oil #8
FWIW, the manuals for both of my rotary cutters (Taylor Way, Bush Hog) say to check the oil every 40 hours. I don't put that many hours on my cutters during a year, so I end up checking the oil in the spring.
Steve
   / brushog gearbox oil #9
as a footnote, if you top it up cold, might also check again once it's warmed up @ operating temp to draw off any excess (aeration/foaming also will affect level)...don't want to compromise any seals on the chance of overfill....regards
Thanks for the responses. what a great source this forum is to get my questions answered!! makes owning a tractor even more fun!
2001 MACK RD688S (A52472)
2001 MACK RD688S...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
