Brushcutter for BX24...any modifications
   / Brushcutter for BX24...any modifications #1
meddac
I'm looking to get a 48 inch brushcutter and was wondering what brand people are using and if they had to do any mods to the 3pt ot get it all working properly. Trying to avoid that. Thanks
   / Brushcutter for BX24...any modifications #2
I have a BX22 and a 48" KingKutter rotory cutter. All I did to it was to lower the lift pins about 6". I could have used the stock pins, but I didn't feel it gave me enough height when lifted.
Lowering the pins is no big deal.. Drill a hole, insert pin, tighten.
And of course, as with any PTO driven implement for any tractor, you will have to size the PTO shaft.
   / Brushcutter for BX24...any modifications #3
   / Brushcutter for BX24...any modifications #4
BX2200 with Gearmore heavy duty 40" model. Search the Kubota forums for BX coupled with brush hog, rough cutter, rotary cutter. There are literally multiple hundreds of posts on this subject.
   / Brushcutter for BX24...any modifications #6
I have a BX23 and a 42" Woods rotary cutter. The pins are pointed in instead of out and it works great with no other modifications.
   / Brushcutter for BX24...any modifications #7
I bought a 48" Howse Bush hog and it hooked up to my BX23 with no alterations. Has been working great!
   / Brushcutter for BX24...any modifications #8
I started the thread spk64 linked to. I didn't have to do any mods to a KK 48" from TSC for my BX24 but the mods did make life easier:)
   / Brushcutter for BX24...any modifications #9
I have Befco Tornado (Model RSD-148) standard CAT1 for the BX2350. No complaints, price was reasonable, and fit and finish was good. Front ballast is a must.
   / Brushcutter for BX24...any modifications #10
I have a Landpride RCR1548 for my BX2660. Works great for cutting all kinds of stuff from grass to weeds and saplings. Well built and actually leaves a decent looking cut. Its often hard to see the line between where I stopped with my riding mower and started with the rotary cutter.
2023 JOHN DEERE 333G SKID STEER (A51242)
2023 JOHN DEERE...
John Deere Hayrack (A50515)
John Deere Hayrack...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
71069 (A49346)
71069 (A49346)
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
